Gauging interest: New AP Racing brake upgrades (the real race stuff)
Location: driving the 10 second beast in ohio or running lightmods.net
if you make a kit i would love to test it on my evo x... (it will fit) i would love to keep similar to stock braking , cheaper pads and drop some weight off the front of my car (especially suspended weight). I race once if not more per week /weekend so they would get some serious testing too lol
From a pure brake performance perspective, what are the top 3 advantages that you would expect to see with these calipers over the stock Brembos (all things being equal- pad compound, rotors, venting, etc.)?
B. Weight- I don't know the stock caliper weight off the top of my head, but I believe it is somewhere in the range of 8lbs.+. This caliper is under 5lbs. I will confirm.
C. Stiffness- While the OEM caliper is a fine design, this caliper is a forged design specifically created with stiffness in mind. We've been using an axial mount version of this caliper in racing for a few years. Most of our customers pulled off other brands of aftermarket calipers and replaced them with these. The universal response has been that the pedal feel and modulation is greatly improved due to the caliper's stiffness. Just because it is a 2-piece design does not mean it isn't stiff. That is a common misconception.
D. SS pistons- These pistons are designed to keep heat out of your brake fluid and prevent fade. The OEM calipers do not have this feature, and are more prone to fluid fade (fluid boils and pedal goes soft).
E. Anti-knockback springs- You will no longer have knockback with these calipers. If you've every run into knockback, you know what a miserable feeling it is to dive into a brake zone and feel your pedal drop towards the floor...not fun, and about a pucker factor 11.
F. High temperature seals- The piston seals on the CP8350 were specifically designed to handle high heat. These are the same seals used in the highest forms of racing (ALMS, Sprint Cup, DTM, etc.). These seals retain their pliancy under high heat conditions, have less chance of leaking, and require less servicing.
G. Long-term use/service- A slew of factors fall under this one. All of the components in the CP8350 are designed to be replaceable and serviceable. All of the stainless steel bits and wear items can be inexpensively serviced or replaced after they start getting worn, whereas the factory parts are more difficult to obtain and expensive. Frankly, the value of dust boots is completely overblown in my opinion. As soon as you put a dust boot under track conditions, it burns up almost instantly, eliminating any value it could provide.
Additionally, being able to send the calipers back to Essex at the end of the season to have them evaluated, torn down, and completely serviced and tested ensures that you'll always be running your equipment in top condition. This is important on a safety item like brakes.
H. Appearance- While not a top priority to most hardcore users, the AP's will hold their appearance much better than the "brownbo's, poobo's, blackbo's," or whatever else you guys are calling them these days.
In terms of "pure brake performance," superior pedal modulation due to stiffness, less fade due to the stainless steel pistons, and the elimination of pad knockback would be three that would be greatly appreciated by any driver on the track.
Jeff: I'm very interested in this kit. A big issue that will determine how these calipers perform is the adapter to allow mounting to the Evo hub. I've had some negative experiences in the past with adapters that are too flexible and allow movement of the caliper body under heavy braking. This led to tapering of the pads and a soft pedal.
Can you give us an idea of what you are thinking for adapter bracket design? I'd vote for the smallest, stiffest adapter possible!
What will it take to have these produced for the EVO 8/9?
Is there an expected run?
evo 8 kit will work on the X with larger with a little drill and tap action...easy as pie
FYI...the first Corvette to use the CP8350 caliper this past weekend at Mt. Tremblant beat the track record for his class by 0.5 seconds in practice, and won his time trial class the following day. Prior to making the switch to this caliper, he was having numerous brake issues. He was running the CL RC8 pad in the CP8350 caliper up front, and the CL RC6 in his OEM vette calipers in the rear. He is quite happy, and we are too. Not bad for the first time out!
I thought this was relevant, since there were a couple of questions about using this caliper on a car that is both heavy and fast like the Evo. At 400+hp and 3000+ lbs. on sticky tires, the C6 vette is definitely both of those things.
Here is the customer's feedback from the vette forum, along with some in-car video:
Got to test out the AP T1 kit at Mont Tremblant this past Monday and Tuesday at the COMSCC time trials. I bought a set of CL RC8 pads from Gary for the front and RC6 pads for the stock rear calipers.
The pedal feel compared to the stock brakes was a huge improvement. Didn't get any fading during the 30 minute sessions and the pedal feel was very, very consistent.
OK, when I read posts like what I wrote above I think, "So what? How hard were you really driving?" If you follow the links below you will see I won my class with a 3.4 second margin of victory and put down the third fastest time of the day. The last link shows some in-car video from a practice session. My car is number 364 in Street Prepared A and is a base model 2006 (non-Z51 / non-Z06) with DA Penske C/Os and this Hardbar/AP T1 brake kit.
This is an excellent kit for the HPDEs and time trials that I do. When the rear caliper kit comes out I'll be in line for that too.
http://www.comscc.org/events/results...?id=2010-08-03
http://www.comscc.org/events/results...?id=2010-final
http://www.youtube.com/watch?v=7GB4Yht-wiI
Last edited by JRitt@essex; Aug 5, 2010 at 01:14 PM. Reason: added customer feedback
I'm more than happy to volunteer my car for testing. I can even take them to the track to test at local NASA events. I don't have nice DAQ though like traqmate or the like. I do, however, have a heavy foot in a 3000lb car with 350WHP and I'm currently having to deal with braking maintenance (cool down laps) to keep my ST-43s usable for an entire 25 min. session. You guys have my email, keep in touch.
I'm wondering if you could use these calipers on the front and back?
would the brake bias upset the car when braking if running it this way.
I have been experiencing pad taper caused by the stock caliper flexing on my Super Touring Evo 8. I am looking at a brake upgrade with true racing calipers as well.
