AMS/TRE sponsored Marty Grand wins STU at VIR
After winning the Runoffs in T2 I decided to try something a little different this year and attempt to race in Super touring under (STU) this season to see how I stack up. The times for STU were about 1 second a lap quicker than my T2 lap time at Road America. STU allows more freedom as far as rules with a couple hard rules such as wheel size 17x8 and restrictor to weight which turns out to be the same restrictor I use in T2 but I get to drop 50lbs.
The coolest thing about STU is it has many former pro WC and GAC cars such as the Stasis Audi, Mazda6 and Realtime Acura and many pro drivers. This weekend was the double National at VIR where I got to run against the Audi driven by Joel Wienberger(pole sitter at 2010 Runoffs), the Mazda 6 driven by Jon De Baros( 6 races with 6 wins in 2011) and a BMW driven by Irish Mike Flynn. I figured this would be the perfect test to see if I could compete in this class.
Saturdays qual went really poorly with a boost issue I was chasing and it rained for the second qual so I was gridded 5th in class and 13th in the run group. After a mad dash I was able to finish 2nd behind the very well driven Audi.
Sundays qual was a bit better and I was gridded 3rd in class and 5th in the group. I will paste the article from the scca below to explain this one. AMS/TRE thanks for a great car with now over 25k miles on it and still running strong.
Marty
In Group 5, defending Touring 2 National Champion Marty Grand changed
to STU with his AMS Performance/TRE/Hoosier/Carbotech Mitsubishi Evo IX
but had the same result as last year’s Runoffs, with an overall win. It
wasn’t easy, though, as he battled Joel Weinberger’s Continental Audi
of Naperville Audi A4 the entire way. It was a three-way battle before
John De Barros’ All Out Auto USA/Hoosier MAZDA6 retired with damage
after seven laps. De Barros’ problem brought out a full course caution,
but only for one lap.
(I was also fortunate enough to set the STU track record in the process.)
http://www.scca.com/documents/Club_E.../SunG5race.pdf
Marty
Marty are you still on the original motor and rings? My 2003 motor blew a head gasket and piston (poor tune) Just replaced the broken piston with a used MR piston and rings. I ran that motor for 4 years until I saw smoke on the upshifts. So last year we rebuilt the motor with the same pistons and new rings. Amazing what these Mitsubishi motors can put up with!
Thanks for the comments!! To answer some of the questions, I will run both STU and T2 at the Runoffs this year. I don't have to qualify for the championship in T2 as the defending champ so I will concentrate this season on sorting the car for STU. In T2 my spec weight is 3480# and 3430 in STU, both require the same 60hp restrictor. Still pretty heavy for a race car but Ill take what I can get. I know the E46 BMW I was running against weighed 2700 and change. My motor is bone stock and all original to include the turbo. I did put on a new HG and belts after the Runoffs tear down
5+ full seasons on the car! Can AMS tune a car or what? Next race up is Summit Point in May, Ill keep you posted.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
