How do I get into road racing, time attack?
I just went to my first road course to watch a little drifting at Summit Point Motorsports park in West Virginia. The drifting was cool but they also had a 2 1/2 mile road course. It was a Porshe Club of America event but there were a few Evo's shredding up the pavement. It was the first time I've ever seen such a thing. It was awesome and I wanted so badly to hop in my x and spin a few laps myself but..... Anyway, I used to, and still do, race motocross. Seems similar but how do I get into such a thing. I'm going to do some autocross next month when it starts in my area ( Maryland) but I wana do some road course, time attack style tracks. The Porshe guys said they had to be a member of the PCA. I'm not gonna join because I don't have a Porshe. Is there a club I can join to get started? Where can I learn more please. Even got the "okay" from my wife.
And what would I need to do to my car? 4 point harness? Anything like that? Sorry to sound dumb but, I am. So any info would be great. Thanks.
There are many group around that you can run with. Look into SCCA PDX's (which I believe DC region is putting a few on at summit point this year), NASA has a HPDE (high performance driving) program that you can try. IMG is another group that I believe is running around you.
Just check the track schedule at your closest racetrack and you should see groups that you can run with. Don't shy away from groups like PCA/Mustsng clubs, etc. usually you don't need to be a owner of that type of car. You might need to pay them for a membership but that's required with almost any club.
The most popular group in your area is probably NASA MidAtlantic, which is who I run with. Summit Point is my home track, and NASA has a lot of events there. I'll be running there this month (28-29th) and its always a good time. You can check out my build thread for some links to the orgs web-site and events. Road racing is about the most fun you can legally have, so if you are interested in it, I cannot recommend it enough.
Summit has a lot of Fridays at the Track events which you could hit up for a quick entry into road racing.
Look at this event too. This is for Virginia International Raceway and it's one of the most amazing courses to drive on. Three days for $400 is DIRT CHEAP too. I can't go sadly as I made plans for that weekend and I'm kicking myself over them...
http://www.motorsportreg.com/index.c...05CF206FBE05FC
Most events require some basic road course knowledge before letting you out there. You'll need to understand the road course flags, general procedures, and event structure before getting there. I think I learned all that from a NASA handbook years ago which you can buy from, of course, NASA
You'll find most events have the same general set of requirements. Car that has passed a safety inspection (no bald tires, brake pads with enough thickness, no leaking fluids, etc.), and a helmet with the proper rating (I believe SA2005 or newer).
Here are my recommendations:
- If you're in Northern VA I I would suggest swigning by OG Racing in Ashburn, VA to try out helmets. They have a decent selection and you can see which is comfortable, in your price range, and of course make sure it's rated for road course duty.
- Make sure basic maintenance is kept up. Change your oil, check coolant (flush it if it's been a while), and change your brake fluid. You'll want to put something a bit more heat tolerant (I like Motul 5.1 personally).
- I would recommend picking up a set of brake pads made for the road course as often stock ones don't handle the temps you'll generate on a real track and will start to fade. I personally like Carbotech's but opinions on track pads are a dime a dozen. If you go with Carbotech pads just call them up and tell them what you're doing and they'll give you recommendations. Don't forget to bed the new pads after you install them!
- You don't need aftermarket harness but they are really nice as even though your stock seats may feel snug in daily or spirited driving believe me you will slide around and feel their real mushyness on the track. I tried CG Locks which add on to the stock seat belt to cinch and hold tight the lap belt and those... worked better than stock. An old trick I learned is to set your seat just a bit back from where you would normally sit, pull your chest strap as taugh, tie it in a knot, and then move your seat back forward. A poor man's harness, and it works ok. I actually think it makes me more secure than the CG Locks
Hopefully others will pop in with tips on how to get into this.
Oh, about the harness, I don't think 4-point harnesses are allowed anymore, are they? I know you can't use them in actual racing generally anymore, and must have 6-points I think. You'll want to check on this, HPDE (High Performance Driving Event) might not care about that.
Highly recommend NASAs HPDE 1-4 to get into TT (then PT).
4pts are not allowed in NASA HPDE or TT (same rules) unless specifically for the car. E.g. Schroth 4pt ASM for e30 M3.
Do not run 5-6 pt harness with the stock seats (not legal either).
DOT4 fluid is a must. And track able pads.
To get started all you need is a car in good mechanical condition (meaning no leaks, fresh brake fluid and at least 50% tire tread, pad/rotor life) and an open mind. That is it! The evo is a very capable car in bone stock form.
Go to www.motorsportreg.com and look for DE (driver schools) or HPDE (high performance driving schools) and sign up for an event close to you with any club. PCA, BMWCCA, Trackdaze, SCCA & NASA all have events in your area. You will have to start in beginner with an instructor and work your way up but that is the fun part. If you already have experience like you say you will advance quickly.
I run with all the clubs I mention on a regular basis. Let me know if you have any specific questions. I'd be happy to answer them.
Hope to see you out on track.
I woudn't really agree with that. SCCA is huge region in DC.
This is something that always irks me a bit. It seems that alot of the new EVO guys only talk about NASA. The fact is that SCCA has been racing ALOT longer then NASA . And, they are still the premier club racing sanctioning body in the US. They also have a good PDX/TT program that might have fallen behind NASA for the time being but, we will be coming on strong in the future! (This is a tought subject to cover but SCCA was just behind the times in letting un prepared cars race TT's) If you never tried and SCCA event i highly suggest it.
it really depends on the region you are in.
I started in NASA years ago and back then their DE program left MUCH to be desired. Clubs like PCA, BMWCCA, Trackdaze & SCCA had much better instruction.
I agree that NASA is doing a pretty darn good job! But, i also saw more wrecks in the 1 NASA HPDE 3 event then i've seen in years of TT's and track days with other groups. Some people think its crazy to have beginners on track with very lenient open passing rules and a huge variety of skill level.
Its a choice just like any choice on where to spend your money. I just don't want people to think that NASA is the only game in town.
Lots of cool groups out there you can run with from PCA, BMW, SCCA, NASA etc. The only one I run track days with is NASA so I cannot speak to the others. I do really enjoy the PCA Potomac autox events though. Really nice folks.
Any track event is a good start. Just you have to start doing it. First time ever i wouldnt worry about anything. Only thing you should care is your car proper maintenance before you going to the track event.
after two or three events you will get a much broader idea about what you need and what do you want.
A have been testing my car an evo track event, and it was quiet good. So you might look around here ,and find EVo guys going on track and going with them for a first time.
http://www.summitpointfatt.com/
I had pretty good luck with instructors there (few years ago, though), plus you get some wet skidpad time in one of their training cars. Summit Main is a good track to start on because there aren't as many turns to remember, and when you are starting out, simpler is better
I think everything else has been covered.
If you can manage a drive out to Gingerman Raceway in Western Michigan, we have a track day set up where you'll see a lot of Evos out there. There is no membership requirement, we just have an anti-douche policy for safety reasons
https://www.evolutionm.net/forums/mo...vopalooza.html
I know it's quite a stretch for you to drive all the way out there, wouldn't blame you for passing on that offer BUT, at the same time it is a great track for beginners. I've only been to the track once but that one time I went there were varying skill levels and of the 3 cars that went off track, none of them were damaged. Only turf buildup in the wheels
