Have some questions about installing a fuel cell.
I'm installing a fuel cell as my tank is rusted to the point of never being used again and need help as this is something I never considered or showed interest in before my situation. Another member recommened posting this here for this.
1st, I need to install a return fitting and have a bulkhead fitting but do I just install it and leave it or do I need to run a hose from the fitting to the bottom of the cell? The cell is filled with foam if that makes a difference.
2nd, there's the whole fuel system wiring harness hanging down, what should be done with it and will any of it be used to properly power the inline Walbro I have?
3rd, I've done a full EGR delete and just completely removed the EVAP canister while removing the fuel tank. Does the harness need to remain plugged in or what? I heard so many answers but don't know what to do with a fuel cell going in. As far as the vent line, it's larger in size over the fuel line and would like to use it as the feed line.
Last, I'm a little lost on connecting the AN lines to the factory lines. I see adapters with compression fittings inside that look nice but are only rated for 50psi. So my idea was to run a barb fitting out of the pump into a 300zx TT fuel filter then to the factory line. The car will make appox. 510-530whp once the tune is done so will this setup work okay or does anyone have a better suggestion?
Any help or suggestions would be appreciated as I can't find much info.
If you want professional help with this, give me a call and we can get you straightened out.
If your interested, and want to save yourself a ton of money, I have a gas tank from a 2005 evo at the shop now in good shape.
If your going to push forward with the cell, remove the evap system. Let the wires all hang or remove the wires and connectors from the connections under the dash, and they make connectors that go from ANto the stock style quick connect fittings. Your gas gauge will no longer work of course, and you'll have to pop the trunk to fill up with gas. I highly recommend to do this if it's a track car only cause I promise it's not worth doing for any street car.
But as far as wiring the fuel pump, can it just be grounded and use the power wire that powered the factory pump?
I just need to know if I can pull the pin out of the connector and wire it to the pump along with a ground is all that's needed to get it running properly.
I have a new inline Walbro 255. Most of the installs I see call for a 30A relay but that's because they're installing it along with the stock pump. I have a fuel pump rewire set laying around if I need to use it but I can't see why would need to yet.
David Buschur
61
Jul 28, 2008 07:20 PM
David Buschur
74
Jan 17, 2007 07:09 AM
