Why is clutch pedal not coming up after full power acceleration?
Edit** Bled clutch line. Air out. Thanks forum members.
My clutch started acting funny yesterday and it continued today. Only after full boost power acceleration (roll-ons), the clutch pedal will not return from floor? I can't engage the next gear until I pull it up with my foot then press again? It works perfectly under normal conditions and mild acceleration runs. I recently had it adjusted so it would engage sooner (closer to floor) verse near the end of it's return.
Clutch brand is Competition clutch stage 3.5 and is newer with just a few thousand miles on it. My car is making 556hp at 28psi.
Where do I start to find solution?
* bleed clutch
* re-oil something
* binding lines?
* bleed clutch
* re-oil something
* binding lines?
Sorry I have no solution to your problem, but I wouldn't recommend adjusting the clutch to engage too far down. The evo naturally prefers a high engagement point for clean shifts.
http://www.teamrip.com/clutch_pedal_...ment_info.html
Good luck!
Good luck!
