For those with carbotech pads...
Just installed a set of carbotech front pads (xp12) with new centric rotors and noticed on the top edge of the pads the material is above the rotor on the front and rear parts of the pad. In the middle of the pad it sits flush with the rotor. Is this normal? Im pretty sure it should sit flush throughout the pad. I double checked the part numbers and they appear to be correct.
Also
Do you guys use any type of lube on the backing plate of these pads?
Thanks
Also
Thanks
I have had the same problem with my Carbotech XP10's. Usually I just take the pad off and add a 45 degree chamfer to the top part of the pad with a grinder to prevent the over lap from happening. Not sure if thats the real solution but it seems to work.
I also use stock backing plates. Although lately I have had bad brake noise even with proper greese.
Thanks! That's was I was thinking about doing. Unsure if it would or could cause any negative effects? I emailed carbotech Sunday, still waiting for a response back.
If you don't have a reply soon you can ask KNS brakes. I purchased some pads from them and they were extremely helpful with all my questions.
I would recommend the backing plates and grease too to help with the noise. A proper bed in procedure is a must! You really should do it on the track but if not then a good stretch of road in mexico during the day would be ok. Are you familiar with the bed in procedure?
http://www.ctbrakes.com/faqs.asp#bedding4
FS[Northeast]: RacingBrakes BBK front and rear
honda-guy
Jul 7, 2016 04:45 AM
WWJPD
Aug 26, 2015 11:39 AM
Mach V Dan
26
Jun 14, 2004 12:19 PM
