How does the ACD reflash and rear diff effect spring rates?
Old Nov 3, 2015 | 10:32 AM
hispanicpanic's Avatar
Another bit i want to add. I was also from the camp that prefer larger spring rates in the rear, which is contrary to all motorsports level suspension enginering.
Then i started playing with my rake and jesus christ. 6mm more rake made the difference between a balanced setup at 8/9 spring rates and rear sway at soft, to a setup that is wildly uncontrollable in oversteer. I moved my rear sway to full soft and reduced rake to control it a bit better
This gives me a hunch that perhaps a spring choice based on corner weights would be best, using rake to manipulate your roll couple and control load transfer front/rear. This deserves serious experimentation.
Old Nov 3, 2015 | 11:30 AM
LetsGetThisDone's Avatar
Originally Posted by hispanicpanic
I'd be willing to bet its more of a bushing issue. I've felt shudders before on my BMW during braking and some turns and it was because the front control arm bushings were beyond shot. The control arms were literally banging inside of its worn out bushing.
What do you have for aftermarket bushings? Engine? Transmission? driveshaft? diff? control arms?
Who is this addressed to?
The reason for a stiffer rear rate is because that is what the car comes, a rear rata that is about 25% stiff than the front. This is due to the rear suspension having a slower motion ratio for the shock. Evo's are about a 60/40 weight bias. BUT, the front motion ratio is very close to 1:1, while the rear is around 1.3:1 (the wheel moves 30% further than the shock)
Old Nov 3, 2015 | 01:00 PM
https://www.evolutionm.net/forums/mo...stagger-7.html
Old Nov 3, 2015 | 01:21 PM
kyoo's Avatar
note how they say stagger is traditional. then again, you drive a 10, which I think people do run square rates. we're talking about 8/9s here.
https://www.evolutionm.net/forums/ev...-your-evo.html
kyoo
618
Jul 27, 2022 12:38 PM
Evopower88
Mar 25, 2016 09:37 AM
WoozZy_Woo
Mar 17, 2016 04:15 PM
amsevokid
Feb 11, 2016 05:15 PM
brett@evogb
Dec 10, 2015 11:55 AM
Quick Reply: How does the ACD reflash and rear diff effect spring rates?
