Swapping between different Hawk Pads
Old Jul 9, 2014 | 12:34 PM
boostincincy's Avatar
Just wondering if anyone has done this on their vehicle as I don't 100% trust manufacturers.
As I've gotten tickets or loud brakes, I prefer to swap pads between track days. With limited resources (garage) in Brooklyn, I try to keep the amount of work between days to a minimum... so I'm considering running Hawk HPS for street, and Hawk DT-60 for track. But if I bed the rotors with the DT-60's, would running HPS in between have a negative effect on my rotors even though it's the same manufacturer?
bless you all
Old Jul 9, 2014 | 01:08 PM
heel2toe's Avatar
Hold the phones...did you say you've received ticket(s) for loud brakes? Is that even a thing?
On to your point what, I understand you not wanting to take Hawks info as they are clearly bias but what did they say?
Old Jul 9, 2014 | 02:44 PM
Balrok's Avatar
LoL, can't say I've heard of that either. But pad material/compound is different between every pad even in the same family so yes you'll need to properly bed them in between swaps and you should be fine. The 60's of course will wear out the rotor faster then the HPS's (which squeak too btw). I guess you would be correct in assuming that scrubbing the rotor between pad materials would provide some excessive wear, but that's the point, you need to wear off old transfer so the new compound works as intended. But it's not like it's going to take whole MM's off.
Old Jul 9, 2014 | 03:22 PM
kaj's Avatar
kaj
swapping within the same family is at least better than going from, say Hawk DTC 70 to Pep Boys. you should be fine.
but seriously: where do you live where you can be ticketed for squeaky brakes???
Old Jul 9, 2014 | 03:52 PM
EVOizmm's Avatar
The only 100% successful story I have for swapping from/to a street/race setup is to swap rotors AND pads together.
Cold stops on race pads essentially "un-bed" the brakes.
Old Jul 9, 2014 | 07:17 PM
I've gotten 4 tickets for loud exhaust, and once was stopped for my brakes, but then "I'm just going to give you a general noise citation for your brakes and exhaust". Which every citation is mandatory court appearance because it's a criminal offense and not traffic. So now I have an exhaust for the track, and a Fujitsubo for street. Need to do same with the brakes.
Old Jul 9, 2014 | 08:18 PM
killerpenguin21's Avatar
i swap between dtc 60's and stoptech streets. i dont do much street driving so i dont bother bedding the stoptechs when i throw them on. there is a noticeable lack of bite though. i do however always bed the 60's before going to the track, and after one session they are where they should be.
Old Jul 10, 2014 | 09:24 AM
Do the Stop Techs make zero noise? Sounds like a decent solution.
Old Jul 10, 2014 | 02:28 PM
i mean a tiny bit, but not constantly. but then again my hawks are pretty quiet most of the time.
SilentCool
Jul 6, 2015 03:00 PM
JBAutosports
EvoX 'For Sale' Suspension / Brakes / Handling
14
Dec 27, 2011 08:52 AM
PaperClip
13
Mar 24, 2011 01:25 PM
sroch23
13
Aug 1, 2007 05:04 PM
Quick Reply: Swapping between different Hawk Pads
