Alignment issues
Alignment issues
For those that track their car, have you been having issues keeping the car aligned? Over the course of the day, i can feel the toe settings change dramatically, In both the front and rear of the car. I usually end up having to eyeball toe adjustments trackside 2-3 times in a track weekend. Also noticed that my front has issues keeping camber/toe as well. Was on a track that had 2 right turns out of 11, and my right front changed camber and toe on me. Steer ahead occured with 15 degrees of steering angle. I eyeballed my camber/toe back to near normal and it kept doing it. Now my front left tophat (vorshlag) reads on one end of the camber adjustment range and my right front reads on the other. And on this same track, my alignment out back which was zero toe turns into positive toe and the car shifts from a neutral feel to full on understeer. But then when i have to turn right, its super oversteer due to toe out on that side of the car. WTF is going on??
Suspension mods include
Robispec KW's
Vorshlag tophats
Perrin Offset PSRS
Whiteline RCK
Hotchkiss sways F/r
295 yoko ad08-r's
Whiteline camber arms
Robispec KW's
Vorshlag tophats
Perrin Offset PSRS
Whiteline RCK
Hotchkiss sways F/r
295 yoko ad08-r's
Robispec KW's
Vorshlag tophats
Perrin Offset PSRS
Whiteline RCK
Hotchkiss sways F/r
295 yoko ad08-r's
Robispec KW's
Vorshlag tophats
Perrin Offset PSRS
Whiteline RCK
Hotchkiss sways F/r
295 yoko ad08-r's
![PC Freak](https://www.evolutionm.net/forums/images/smilies/freak.gif)
One other thing that may be is your wheel bearings. Do the test and see what you get.
Then start with your front tie rods, are they bent, are the ends whiteline or oem, is the backup nut moving (white paint marker). I've never used the whiteline camber arms I can't comment on those. Then check every nut for torque and re-measure everything on a flat surface. Or take it to a good shop and have that thing looked at.
Sounds like fasteners aren't tight. Mark every nut and bolt head with paint pen and see what is moving..
Fastners are tight. I have hairy palms.
Inspected hte uprights last week and found nothing. I'll be removing control arms this weekend and removing the downpipe and stuffs to try and get a solid look at the steering rack/subframe.
rhitme03
Feb 18, 2004 11:00 AM
a904dam
Feb 18, 2004 06:10 AM
