evo 9 hillclimb build log
JoshMS6 (Apr 27, 2016)
NJ9MR (May 4, 2016)
Here it is on the table putting the peel ply layer:
getting vacuum setup:
it was laying weird on the table so we sat it on the car overnight to cure:
the bottom was sucked TIGHT!
a few lessons learned:
we were worried about the mold being too flimsy so we threw a strip down the middle for bracing. This made it rock during layup and also slightly warped the mold from the added heat of that epoxy.
Make sure the plastic is square before you tape a corner. we didn't double check both sides and had a couple weird folds that required extra care to seal.
just like everything we'll do it better/cleaner/faster next time
