Knee Pads
I know you've read how bad it is to have a harness and a non-containment seat? Any instructor or driver will tell you you're loosing concentration by focusing on bracing your body, which could lead to mistakes. So I'd simply say to find a way to swap seats if you're that concerned with the looks. If done right 4 bolts should take one out and put another one down. Personally there are some racing seats out there that look better and feel more comfortable then the OEM's.
+1 on the seat. in my street evo there is a rub mark from bracing myself on the door card. in the race car we have a full containment seat and it is amazing how much less effort it takes to drive the car when you don't have to focus on not sliding around.
in my off-road race rzr i have and ultrashield rally seat that works well but i still move a bit (and its much rougher) so i put a 6"x6" square of dense foam on the door panel where my feet were rubbing.
I came in here to make a joke but I guess you're talking about a different kind of knee pads so Ill see myself out...
Actually scratch that. How tight are your harnesses? I think we have the same setup i.e Schroth 4 point ASM's or whatever its called. When I buckle up I clip in with the betls loose and then crank em down. I used to use a CG lock before I upgraded to harnesses and I used to have burns on the outside of my knee too. But now with harnesses it doesnt really happen, or at least not nearly as bad.
Ya i've been resisting asking what Kyoo was doing with knee pads when I read the topic too .
I'm also guilty of installing 4point ASM's when I started out, but after seeing first hand how that combo does NOT work in those conditions I quickly adjusted my plans.
Worth considering - just this last weekend one of our regulars met unfortunate conditions which led to an impact but since he spent money on seats/half cage/safety stuff first he literally walked away without a scratch. Knowing all the knee issues people have I wanna keep mine intact and no pad is going to help with that. Ya it's best to do full stuff, but even the Bolt in's are hundreds of times better and you still keep the carpets.
You're best to swap seats really. I built my car slowly and remember getting to the point where I was in pain driving home after a track day from trying to keep myself in place. After I switched seats not only did I never experience that again but I picked up a few seconds at my home track as I was no longer focusing on staying in my seat and could just drive. Not to mention the safety aspect as Matt touched on.
Yes on pads, but on the driver, not the car.
Trick came from AutoX guys, who would use volleyball knee pads to keep from banging up knees/lower legs. It's easier than "installing" on the car, and protection stays with the leg.
Of course, AutoX can be more "frantic" than road racing, you didn't say what kind of racing you were doing.
I prefer sitting further back if I could, that gives you more stretch to the leg and less fatigue.
