Sup w/them 2024 Fall Projects?
Old Nov 19, 2020 | 10:47 AM
  #2431
Dallas J's Avatar
Veteran: Army
Originally Posted by Balrok
Still nothing, did he get back to you?
Im not going through JRR directly, going through English Racing. So I assume they can get a hold of him easier.
Old Nov 21, 2020 | 09:56 AM
  #2432
kyoo's Avatar
my car must run cool, i consistently see more like 150-160. it is cooler out and i'm not driving hard though
Old Nov 21, 2020 | 11:51 AM
  #2433
kaj's Avatar
kaj
Thermostat?
Old Nov 21, 2020 | 12:04 PM
  #2434
kikiturbo's Avatar
Finally got off my back and started putting the dry sump together. The pulley needs to be machined a bit more, as it will not run with the ribbed belt going around it but will run it counter clockwise from the back of the belt.. so V band profile needs to go. Will take the pump apart and set it for counter clockwise rotation.
Tank is next, after I finish the sump...
alpinaturbo (Nov 21, 2020)
Old Nov 21, 2020 | 12:20 PM
  #2435
kyoo's Avatar
Originally Posted by kaj
Thermostat?
OEM thermostat, OEM radiator, zerex blue + a bottle or 2 of water wetter. possible it could have gone bad i guess?
Old Nov 21, 2020 | 01:00 PM
  #2436
kaj's Avatar
kaj
That's what I'm wondering.
Old Nov 21, 2020 | 01:37 PM
  #2437
EVO8LTW's Avatar
That’s cool enough to potentially affect the tune. I don’t think my car would even see closed loop at 150.
Old Nov 21, 2020 | 03:58 PM
  #2438
Balrok's Avatar
Odd it hasn't thrown a code yet, if there is a code.
Nice setup on the dry sump. Be sure to move the oil drain over towards the driver side to make even more room for downpipe setup.
Old Nov 22, 2020 | 08:37 AM
  #2439
EVO8LTW's Avatar
Originally Posted by EVO8LTW
Ugh...just installed Walbro 450 and I obviously messed something up, Car starts, runs for a second, builds 18 psi fuel pressure and then dies. I’m suspecting that I didn’t fully seat the grommet/output of the pump in the housing, or I tore the grommet. I failed to lube that before installing it and I did notice after install that the bottom of the grommet was still slightly visible, which I understand isn’t normal. I should have redone it right then and there. Only other thing I can think of is that possibly the strainer is too close to the bottom of the tank because this new pump design is longer. But, I doubt that because I got the bottom pump bracket fully seated with all 3 clips. Anything else to troubleshoot?
Originally Posted by heel2toe
Sounds exactly like a grommet issue. I've run into this in the past and only saw about 20# at the rail when cranking. And your logic with the bottom bracket clipping back in is sound so it really can't be that. Pull it back apart and see for yourself.
It actually wasn't the pump grommet. It was the o-ring not reinstalled properly on that grounded plastic clip by the fuel filter. Rookie mistake for sure. As soon as I pulled it apart I realized that the o-ring needs to be reinstalled around that little nozzle thing and not just free floating in the tube!
But now the car idles fine with the new Walbro 450, drilled siphon, McMaster bulkhead fitting for wires (to bypass the melt prone stock clips in the stock hanger), FIC 1650s, Spoolin Up resistor delete plug, Radium fuel rail, fire sleeves on the underhood lines and Innovate flex fuel sensor wired to the stock ECU. I was expecting the fuel pressure to be 50+ psi, but it's actually right at about 42 psi with the vacuum line pulled from the stock FPR. Now to finish up the Hobbs switch relay setup, though it's mostly done. This has been a much more expansive install than I was expecting, and this is just a simple single pump set-up!
alpinaturbo (Nov 22, 2020)
Old Nov 24, 2020 | 12:23 PM
  #2440
Construct's Avatar
I've been severely neglecting the Evo since my son was born, but SSB Design's Black Friday sale was too good to pass up.
I'm joining the billet upright club next season. Also ordered the billet front LCAs to push the wheel forward. Need the extra clearance at the rear of the wheel well to get the 275/35s to fit.
Old Nov 24, 2020 | 12:52 PM
  #2441
EVO8LTW's Avatar
i just ordered rear trailing arms. Looking forward to wider wheels in 2021!
Old Nov 24, 2020 | 01:41 PM
  #2442
Dallas J's Avatar
Veteran: Army
Old Nov 24, 2020 | 04:25 PM
  #2443
LetsGetThisDone's Avatar
The sale is tempting... but the car needs other things right now
Old Nov 24, 2020 | 04:27 PM
  #2444
kyoo's Avatar
i don't think it's legal in my class, but what's the main takeaway? more grip and better handling?
Old Nov 24, 2020 | 05:10 PM
  #2445
Ayoustin's Avatar
Unless it's spelled out as being illegal, it's not illegal. IIRC street rules just say you can't modify pickup points on the chassis.
But yes, more mechanical grip because it puts the car in a better behaved area of the camber curve when it's lowered.
I ordered myself a set of the LCAs as well. First person to place an order on his new site too 😜 This rounds out my SSB collection, now I have every evo specific part he makes 😂😁
Quick Reply: Sup w/them 2024 Fall Projects?
