Sup w/them 2024 Fall Projects?
Old May 24, 2021 | 03:57 PM
  #3136
kaj's Avatar
kaj
I wonder how close that AYC unit is to ACD. Looks really close.
Old May 25, 2021 | 05:17 AM
  #3137
kikiturbo's Avatar
Originally Posted by Balrok
Ya it looks like they only handle the AYC units. USDM 9's are only ACD pumps to the center diff.
no, on the eudm and jdm cars with AYC the same pump runs both ACD and AYC... we just have 3 solenoids on the same block
also, our evap is under the hood..
Old May 25, 2021 | 11:23 AM
  #3138
Bee-Raddd's Avatar
Its the same thing it just has an extra solenoid and output for the AYC
Old May 25, 2021 | 12:43 PM
  #3139
kaj's Avatar
kaj
I'll have to look into that kit a bit closer, then.
Old May 25, 2021 | 01:56 PM
  #3140
kikiturbo's Avatar
dont need a kit.. just some longer lines and a bit of wiring..
Old May 25, 2021 | 06:14 PM
  #3141
kaj's Avatar
kaj
Well, yeah.. after fabbing up a bracket, researching/buying/forgetting/buying more fittings, etc. Or, just hit the easy button since someone has already done all that.
Old May 25, 2021 | 07:49 PM
  #3142
Bee-Raddd's Avatar
i wouldnt be surprised if the wiring was there even in the loom. just not plugged up.
You can buy flexible braided line kits for them or just make your own. the factory line is a hard line that runs along the loom where the brake lines run
Old May 25, 2021 | 09:08 PM
  #3143
kaj's Avatar
kaj
It would make sense to use the same harness, but I haven't seen anything like that back there. That would be too easy.
Old May 25, 2021 | 11:43 PM
  #3144
kikiturbo's Avatar
If I saw the right link, the kit is for the JDM/EUDM cars which have the pump in the.. so you need to make your own lines anyhow..
Old May 26, 2021 | 12:05 AM
  #3145
deeman101's Avatar
Unfortunately it's not there. I did look hopefully lol. Only way is to extend the harness from the engine harness up front.
Old May 26, 2021 | 01:02 PM
  #3146
kaj's Avatar
kaj
I can show the lines to somebody and tell them " make me these, but more longer " LOL
THAT I can do
Old May 26, 2021 | 06:57 PM
  #3147
deeman101's Avatar
THAT I can do
The hydraulic lines? The fittings are inverted flare m14x1.5. And use something that can take up to 200psi at most.
The following 2 users liked this post by deeman101:
kaj (May 26, 2021), kikiturbo (May 26, 2021)
Old May 26, 2021 | 07:11 PM
  #3148
Dallas J's Avatar
Veteran: Army
I found the best option to be just cutting the existing line and putting a hose on it with double clamps. I know the pump says it can make some crazy pressure but Ive never logged more than 90psi.
kaj (May 26, 2021)
Old May 27, 2021 | 08:30 AM
  #3149
kyoo's Avatar
fyi - shop's got the buddy club sliders & the recaro al brakets - they do not fit, which is surprising.
Old May 27, 2021 | 11:25 AM
  #3150
LetsGetThisDone's Avatar
Can always use a flare tool to flare the line as well, give the clamp something (a "barb") to butt up against.
Quick Reply: Sup w/them 2024 Fall Projects?
