Sup w/them 2024 Fall Projects?
#5596
#5598
Not just the damper face to the gear, but also the gear to the spacer, and then the face of the crank to the spacer (the spacer that replaces the balance shaft gear).
I've seen the issue mostly in cars that see the rev limiter or the 2-step a lot, so drag racing and autocross.
#5601
Originally Posted by griceiv
how does oil and red loctite mix? meaning the correct torque spec is for oiled crank bolt.
Any other cool questions?
LetsGetThisDone (Aug 25, 2023)
#5606
Originally Posted by Lumpy Sticks
That Evo still running good? I need to catch up with you and Tom one of these days!
alpinaturbo (Sep 2, 2023)
#5607
7163 was pretty nice, but we found it just slightly more laggy than we liked for tight digs. The blouch 1.0 was just a few hundred rpm quicker and it was quite noticeable. Though I know Shoe was running a Green and 2.2 (maybe still is?) and he's never seemed to have issue with it.
#5610
The trans is awesome. My mind was blown when I went for a ride in it.
