Sup w/them 2024 Summer Projects?
Old Aug 18, 2020, 09:01 AM
  #2011
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
Subaru's spool like ***.
Evo8, no mivec, 2.2 short rod, pocket port head, GSC S2, ETS turbo kit, .83ar vband G30-770. No boost spike, flat 29psi. Maxed out injectors.
The lag the dyno sheet shows is not very apparent on the street.
Attached Thumbnails Sup w/them 2024 Summer Projects?-photo423.jpg
Old Aug 18, 2020, 09:06 AM
  #2012
Here is data from the other thread-
As promised, logs of the spool up in 1-4, and also a 1-4 rip to show transient response. It honestly feels identical to the MHI FP red when it was on my stock engine (non-mivec 2.0, S2's). This car is a non-mivec 2.2 with S2's.
First one has the 1st, 2nd, ad 3rd gear log files, 2nd one has 4th gear and the 1-4.
https://datazap.me/u/letsgetthisdone...2-3&hg=1-1-2-3
https://datazap.me/u/letsgetthisdone...3-4&hg=1-2-3-4
Old Aug 18, 2020, 09:19 AM
  #2013
kaj
kaj's Avatar
Originally Posted by Dallas J
Watching the new Speed Academy video of them putting a G30-660 to upgrade from their G25-660 the lag on it seems pretty miserable I know its a hub dyno but showing 300ft-lbs at like 5200 rpms which was 900rpm slower. So even the G25 waw 4300 and the smaller turbine only making low 400s. Wonder what that translates to dynojet? Either way is that just what subies see?
Are we just spoiled with short runners to get low 3ks to 300, 500hp, and 8k reving? Seems like a hard sell to ever build a suby with that weak potential
(Slight trolling, still not very impressed tho)
I had a Subaru for about six months. It was just after I sold my first Evo and I sold it to buy my second, if that tells you anything.
I know they have a huge fan base, but other than rally fans, I don't get why.
Old Aug 18, 2020, 10:31 AM
  #2014
EVO8LTW's Avatar
The walbro 450 will run out at around 580-600whp with 1650 injectors depending on the setup. The 525 will flow enough that the injectors become the limit around 615ish. That sounds like you have the right idea for wiring, you can have the hobbs switch set to come on at 5-10psi of boost. Except the ground, just make that a dedicated 10ga ground wire; don't worry about the factory ground wire or anything.
Both the 450 and 525 over run the regulator, even with the siphon drilled to 9/64 (drill siphon required with either pump). It's easy to tune around because higher pressure at ultra low (idle and cruise) pulse widths actually makes bigger injectors act like smaller injectors and makes them more consistent. The two cars I have running ID2000's actually idle and cruise better with 55psi base pressure. So it's not really a concern.
I would replace the OEM rail with an AEM or other drop in replacement for the factory rail, it has more volume and will help maximize power availability for a given pump/injector combo.
Also, the 450 and 525 go int the stock housing without modifying or deleting the factory filter assembly, so there's no need to run an inline fuel filter.
Good idea on fire/heat sleeve for the return line. I would also replace those hose sections with new, STM can you the correct Gates hose to replace it with it.
Hopefully that answers everything for you.
Awesome, thanks!
Old Aug 18, 2020, 10:35 AM
  #2015
EVO8LTW's Avatar
The G-series Subaru results vary pretty widely. Check this out:
Old Aug 18, 2020, 11:02 AM
  #2016
Veteran: Army
Dallas J's Avatar
Spool on that is substantially better, is that cause FA motor?
Old Aug 18, 2020, 11:10 AM
  #2017
STI is still an EJ25. FA only comes in the base wrx.
Old Aug 18, 2020, 11:17 AM
  #2018
Veteran: Army
Dallas J's Avatar
Oh true, I knew that but was just looking for a "why" for that one being some much better responding.
Old Aug 18, 2020, 12:06 PM
  #2019
Could be any number of variables honestly. Tune/cam timing, turbine housing AR, turbo kit design, intake, intercooler, Exhaust system, etc..
Old Aug 19, 2020, 12:56 PM
  #2020
Balrok's Avatar
So this time at least I can blame the wife for buying a 2nd race car and for making me broke again haha. Ohlins, clutch, Jacks had a tranny in stock, sways, links, brakes, various worn engine bits...haven't even got wheels or tires yet.....sigh.
Old Aug 19, 2020, 01:43 PM
  #2021
kaj
kaj's Avatar
We understand. It's taking everything in my power to not mod my other toy. I will put wheels on it, eventually, but that's it. I was going to lower it.. but nah. It's hard to fight the urge.. but I really do enjoy just driving it.
Old Aug 19, 2020, 07:32 PM
  #2022
Balrok's Avatar
Well most of "those" parts are either worn, broke, or straight wrong on this car. When I flip it I'd like them to know if it was mine they'll know it was done correct. I'll likely do a "wow, really?" build thread lol.
Old Aug 19, 2020, 07:34 PM
  #2023
kaj
kaj's Avatar
Well, I mean if you gotta...
Old Aug 21, 2020, 06:54 AM
  #2024
EVO8LTW's Avatar
As I'm looking at what all this stuff costs and the number of parts to replace, plus the potential for having to do extensive low load retuning, I am left wondering whether a 255/255 double pumper might be a more elegant and easier solution. If the Walbro 255 is, as a practical matter, E85 compatible, then it seems like two smaller pumps would be easier than one big one. We don't need to keep this discussion going in the Motorsport forum. It's not really what this forum is about.
Old Aug 21, 2020, 07:29 AM
  #2025
Biggiesacks's Avatar
I dunno about that. If your moving to 2 pumps then you are either going to an aftermarket fuel hanger or greatly modifying the OEM. Either way you would be removing the OEM filter so you would be required to install an inline filter. The wiring for 2 pumps is a little more extensive than just a single. As far as tuning goes, I can't speak for very large injectors I only run 1200cc, but moving from a single 255 to a 450 only required a little tweak to the hi/low crossover point at lower RPM. I think using less parts to do the same thing is considered more elegant, and generally more reliable.
Quick Reply: Sup w/them 2024 Summer Projects?
