Sup w/them 2024 Summer Projects?
Old Oct 7, 2020, 08:55 AM
  #2281
kyoo's Avatar
Originally Posted by kaj
That looks like a really nice alternative if someone already has water and coolant in the car. Mine only builds about 5-7psi of pressure, which is the #1 I use it, but I see no corrosion or electrolysis also with the Redline which is my #2. LOL
solid looking stuff. Me likey. Nice find!
yea i'm interested, they don't explicitly mention cars and i'm not sure if our car's coolant is ASTM D2570 and ASTM D1384 qualified but very interesting
Old Oct 7, 2020, 09:06 AM
  #2282
kyoo's Avatar
looks like that is the motorcyle version, this is for the car: https://www.redlineoil.com/supercool-performance
kaj (Oct 7, 2020)
Old Oct 7, 2020, 09:14 AM
  #2283
Lumpy Sticks's Avatar
Originally Posted by Construct
Hankook R-S4 are great track tires if you're looking for best bang for the buck.
They last forever, grip decently well, and handle heat better than the modern 200TW tires.
Originally Posted by ayoustin
Hankook RS4 or Maxxis VR1 for something that will be fairly quick and last on track. Either will last a full season.
Hankook R-S4 is a killer tire. It performs a bit above it's price range and can take 20-30min beatings without blinking.
Thanks guys. I will see if they make them in the size I need. I am letting a buddy drive my Cobalt at Streets of Willow at the end of the month and he said he would pay for half the tires as a thank you. Now I need to finish getting the Evo ready since I wasnt planning on taking it. Got the Girodisc titanium shims and some ST43s to put on as well as a brake fluid flush. Easy stuff.
Edit - RS4s are out. They dont make them in the right size.
Old Oct 7, 2020, 12:41 PM
  #2284
What about the Federal 595 RS RR? I can get a set for $440 out the door. Everything else is over $600 by the time I pay for tax and shipping.
Old Oct 7, 2020, 01:04 PM
  #2285
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
I wouldn't. Things get expensive when the carcass comes off the sidewall.
Old Oct 7, 2020, 01:11 PM
  #2286
kyoo's Avatar
has anyone run both a 1-way and 1.5-way front on track? i know marhsall has for autox, dunno if for track it will be different, seems like a lot of track guys run the 1.5-way front diff, and the autox guys run the 1-way front
Old Oct 7, 2020, 01:24 PM
  #2287
lv05evo's Avatar
Check out this thread:
https://www.evolutionm.net/forums/ev...l#post11920318
Old Oct 7, 2020, 01:35 PM
  #2288
Construct's Avatar
Did you check Hankook's site, or Tire Rack? Tire Rack is out of stock of a lot of R-S4 sizes for some reason.
Old Oct 7, 2020, 02:23 PM
  #2289
Ohh that sounds like it could be a fun ride!
Originally Posted by lv05evo
Thanks. Will look at the thread.
I have checked at least 15-20 different places. The only size I see offered would be perfect for my Evo. 265/35-18. But I need 225/40-18 for the Cobalt.
I found a set of NT05s in stock locally (and a buy 3 get 1 free) but I think at that point I would prefer the 615s. Everyone is out of stock on them though. I got about 2 weeks to get something or I will be out of time. If my search keeps going like this, I am really tempted to just buy some 17" wheels and use the 615s I have laying around. But at the same time, the car has a stupid offset, 5x120 bolt pattern and has Brembos that dont clear most wheels. Might as well just send it on the 5 year old 500TW tires it has on it....
Old Oct 7, 2020, 03:37 PM
  #2290
I'd pull the tirgger on the NT05's. They're an old tire as they've never been redesigned since their initial release a long time ago, but they're proven and work well. And apparently in stock with a BOGO deal. Seems like a no brainer to me..
Old Oct 7, 2020, 03:52 PM
  #2291
kaj
kaj's Avatar
They like to come apart. No bueno.
A for NT-05s. I've broken off chunks of them during HPDE. That's after a warm up lap. I used to have pictures, but it was a long time ago. Stock WHP and weight.
Old Oct 7, 2020, 03:54 PM
  #2292
kyoo's Avatar
that's tricky. any way you can fudge a size close enough on the rs4s?
Old Oct 7, 2020, 04:57 PM
  #2293
Veteran: Army
Dallas J's Avatar
Filling the reservoir on extended sessions is normal. For track days, I make sure my reservoir is empty, and leave about an inch of room in the radiator for expansion. Pretty much the same thing you do on a dirt bike because they don't have an expansion/overflow tank. The over flow line just drains to the ground, so even if you fill the rad up it just bleeds off the excess as it warms up.
Good to know thats common. I done track duty before but never noticed. Usually on track I turn things down more like 20psi but we were at 25psi for this smaller event and driving quite a bit more aggressively with less airflow.
Old Oct 8, 2020, 09:30 AM
  #2294
I am going to keep looking for other options for now. That deal is good for the month so as long as they keep the tires in stock ill be fine.
Keep in mind this is a 300whp FWD turd that weighs around 2700lb. Not sure if that going to help with chunking.
I dont think that they make anything close enough in size. Even if they did, it seems like everyone is out of stock.
Old Oct 8, 2020, 11:15 AM
  #2295
kaj
kaj's Avatar
Keep in mind this is a 300whp FWD turd that weighs around 2700lb. Not sure if that going to help with chunking..
Probably as fast or faster but being a few 100lbs lighter should definitely help.
Quick Reply: Sup w/them 2024 Summer Projects?
