Sup w/them 2024 Summer Projects?
#2687
Compression seems fine still though. At least, It can definitely be set too much in bumps and becomes super harsh.
#2698
This is not always true. Fixed back seats are less safe if you're using a 5 or 6 point harness without a roll bar. They are perfectly fine if you retain a functioning 3 point belt. The seat itself is more structurally rigid that the factory seat in most cases.
#2700
I did keep the OEM seatbelt, in case I drive the car around town. So, that means I also kept the airbags too. I haven't quite decided to go full-on race car, yet.
