Sup w/them 2024 Summer Projects?
#3122
41's, had given them a shot and liked.
circling back tot he acd pump relocation discussion - looking under the car, it looks like if you want everything on the driver's side, you have to get rid of some emissions stuff for the usdm 8/9s - not an option for me. we can locate everything, pump and all, inside the trunk on the driver's side, or relocate it on the passenger's side with the potential of exhaust heat issues - thoughts?
also - anyone got a line on some inexpensive x calipers? mine need to be redone/replaced.
alpinaturbo (May 20, 2021)
#3124
It might be tight actually to mount it inboard of the Evap equipment. The black reservoir is too big in diameter. Here is my radium fst mounted in that position. You could mount it further forward to clear the widest part of the trunk pan but it might get close to the mustache bar (assuming you still have that). Mounting in the trunk like the Evo X relocation kits has some drawbacks but can definitely work.
#3128
I was just watching that G&G video and was like.. is that the same Kyoo from EvoM?
#3129
https://www.irs.gov/faqs/small-busin...ncome-expenses
#3134
I have no idea what the evap is but the JDM pump is located in the left rear corner of the rear bumper under the boot floor outside of the chassis rail.
Theres also an option like this: https://www.autotorque.net/tag/ayc-pump/
