Sup w/them 2024 Summer Projects?
#4306
camber and toe locks in place. what's left is:
- UICP, and LICP if there's time
- Turbo inlet tube
- Strut tower brace (5.4lbs, apparently stock is only 8lbs anyway...)
- Remove cross brace by the downpipe (unless anyone thinks it does anything)
- RS Trunk Brace
- Battery fuse
- Re-grease the rear bushings/ball joints
- Temp tape on bushings & abs sensors
- Install upright > e-brake > hub > reassemble brakes
- Make sure everything is torqued down
- Bleed brakes
- Align toe
- Turbo inlet tube
- RS Trunk Brace
- Battery fuse
- Bleed brakes
- Align toe
#4309
Yes. The braces on the bottom.
Not saying any of those items are useless, just that I didn't notice any difference. I was told the fender braces do the same as the strut brace, so opted for those so my engine bay was easier to access. That brace always seems to be in my way.
