Sup w/them 2024 Summer Projects?
Old Mar 29, 2022, 08:25 AM
  #4681
kyoo's Avatar
i'm on street tires, so xp8 may work fine for me for autox purposes
Old Mar 29, 2022, 08:28 AM
  #4682
Veteran: Army
Dallas J's Avatar
I use XP10 on A052 and A7s. I also have a few higher speed events to deal with but they dont have any problem in the cold months on the small course. The downside to them is wear rate on track. For AX its NBD, for track they may only last a couple events.
Old Apr 1, 2022, 08:57 AM
  #4683
Balrok's Avatar
Sigh. Has anyone felt a mechanical grinding/vibration on the 1st inch or two of clutch pedal travel before? You only feel it when the cars on and spinning, so I'm thinking it's the TOB but that sucks cause it's only got maybe 30 miles on it. EvoX FE car.
Old Apr 1, 2022, 09:01 AM
  #4684
Veteran: Army
Dallas J's Avatar
Yes, when using non-oem TOB. This one was 1 summer old. I knew better, but was in a pinch.
View this post on Instagram
alpinaturbo (Apr 1, 2022)
Old Apr 1, 2022, 12:43 PM
  #4685
alpinaturbo's Avatar
Dallas, OEM TOB with ACT Monoloc Collar?
Old Apr 1, 2022, 12:55 PM
  #4686
Veteran: Army
Dallas J's Avatar
That clip was an ACT TOB, never had problems with OEM TOBs in all my DSM/Evo years (since 99')
  #4687
ViciousLSD's Avatar
do you need to grease the TOB? I just put mine together (1st time, PITA) and realized i should have probably greased it. seems there's no way to shoot grease up the hole
Old Apr 1, 2022, 02:12 PM
  #4688
Veteran: Army
Dallas J's Avatar
I have a whole process. Yes, I definitely grease the inner race of the TOB and theirs an inner groove to hold it.
I also use a triangle file on all the splines to remove any burrs on both the trans input shaft and the pressure plate. Put grease on the splines then wipe it all off. A small film will stay and thats pretty much all thats needed and wont sling off.
deylag (Apr 1, 2022)
Old Apr 1, 2022, 02:58 PM
  #4689
ViciousLSD's Avatar
Thanks. I just hope it will be fine until I need to go back in there for a clutch job. I did put grease on the fork, 'ears' and moving parts.
I also put lithium grease on the splines but I brake clean'd it off after realizing it could end up on the friction surface. I have a small file set i haven't used and will try your tip when i get a new clutch
Old Apr 2, 2022, 07:17 AM
  #4690
Balrok's Avatar
I've always used OEM except once, but this is the first OEM one to fail, let alone so quickly.
Old Apr 12, 2022, 11:24 AM
  #4691
Bee-Raddd's Avatar
crickets...
Old Apr 12, 2022, 11:26 AM
  #4692
kyoo's Avatar
this is what happens when i no longer have my car with me haha
Old Apr 12, 2022, 12:13 PM
  #4693
Veteran: Army
Dallas J's Avatar
I’m just over here completely overwhelmed trying to get enough done before packing things up this weekend to move into new house/shop.
on the plus side, I bought a compact tractor
Old Apr 12, 2022, 12:45 PM
  #4694
ViciousLSD's Avatar
just did this project
https://www.evolutionm.net/forums/ev...l#post11952363
Old Apr 12, 2022, 02:58 PM
  #4695
Bee-Raddd's Avatar
ive been busy as per usual. At our last round a few weeks back we had an absolute mare,
Second lap of first practice the bung which comes with the drysump kit and is inserted into where the dipstick used to go came out and sprayed oil absolutely everywhere. had to shut the car down on track and roll into pits. had a small fire from the oil which burnt all my lower timing cover up 13 weeks wait from mitsi for replacement! :'(
Spent all day cleaning that mess and had to pull the intake manifold off to get down to the hole so i could plug it. Luckily one of the other competitors dad is a machinist by trade and we managed to organise a lathe to use so we spun up a new bung and tapped that in.
Went out for qualifying which went reasonably good. Car sounded a bit funny and was laggy out of turns. found that the exhaust manifold had cracked just above where i had the V band welded onto the manifold collector. The manifold is quite old so the steel looks like its in average condition and the penetration was average on the weld. We also noticed a little seep on one of the drysump fittings. went to give it a check for tightness assuming it may have backed off a bit and the fitting itself had cracked straight through the o ring groove. So panic stations to sort another fitting out. Had to downsize the hose size from -16 to -12 and get a new hose made up. No time to fix the cracked manifold.
Went out in the race and the manifold eventually cracked all the way through which lost 90% of my boost so we just limped around to get points. Whipped that off in the evening and managed to get it welded by somebody at around 11pm. All fitted up perfect in the morning went to run the car up and the alternator wasnt charging the battery up anymore. Checked alternator and it wasnt putting out a charge. Dead alternator! suspect when it got showered in oil it may have ruined it. This unfortunately put us on the trailer which sucked after all the effort to get going on the previous 2 days.
Weve lost contact with the top 2 guys in the championship now but we are 5 points off 3rd place so its all on for 3rd with 2 rounds to go.
Over the past week ive replaced the alternator with a new high output one, Replaced the power steering tank with a STM one as my standard one was spitting out fluid. and upgraded the drysump fitting that broke to a steel version rather than alloy. Now we wait till next weekend for round 4!
TimC909 (Apr 16, 2022)
Quick Reply: Sup w/them 2024 Summer Projects?
