Sup w/them 2024 Summer Projects?
Old Apr 11, 2019, 09:02 AM
  #481
Balrok's Avatar
For Bee? He's after that show car StAnCe lol. With full slicks you usually run between 3 and 4 deg.
Old Apr 11, 2019, 09:06 AM
  #482
MrAWD's Avatar
Even in the rear?
Well, never run slicks on the road track, but that is a lot from autoX perspective! How do you even make it to turn with that amount of camber?
Old Apr 11, 2019, 09:19 AM
  #483
Veteran: Army
Dallas J's Avatar
Originally Posted by MrAWD
Even in the rear?
An ASP evo needs around 4-4.5 deg of front camber and 2.5-3deg of rear camber.
Old Apr 11, 2019, 09:32 AM
  #484
MrAWD's Avatar
I believe that! I was just surprised to see things over 3 degrees for the rear end.
Old Apr 11, 2019, 09:33 AM
  #485
MrAWD's Avatar
At the same time, what would STU require?
Old Apr 11, 2019, 11:43 AM
  #486
Construct's Avatar
I preferred 3.7 up front and 2.1 in the rear in STU trim on my IX. Some people prefer rear camber in the 1.5 range for a looser setup, but I could never get that to feel right in the sweepers.
Old Apr 11, 2019, 12:22 PM
  #487
Bee-Raddd's Avatar
Normally run 2 to 2.5deg in the rear and 4 to 4.5 deg up front fellas
Think the angle of that pic is distorting it a lil.
And yea its a full wrap its chrome and alot brighter in person. Been on there for a couple rounds of racing so far
Old Apr 11, 2019, 08:59 PM
  #488
griceiv's Avatar
good to know, I'll go take out some camber from the front and rear of Tom's car.
Old Apr 11, 2019, 10:01 PM
  #489
Veteran: Army
Dallas J's Avatar
Haha, straight from the horses mouth
Old Apr 12, 2019, 09:10 AM
  #490
Meathooker's Avatar
lol i was thinking the same thing.
iirc i had around 5 or 5.5 in my car when i did autox
Old Apr 12, 2019, 10:00 AM
  #491
MrAWD's Avatar
I have no issues with larger front camber - you get as much as you need to keep things happy!
But, having much more than 3 degrees in the rear is surprising...
Old Apr 12, 2019, 09:27 PM
  #492
griceiv's Avatar
Rear camber lets you crank up the rear roll stiffness and also helps reduce the understeer caused by the rear diff preload.
That said we're only at like 3.2 deg in the rear.
alpinaturbo (Apr 16, 2019)
Old Apr 13, 2019, 09:15 AM
  #493
MrAWD's Avatar
Makes sense!! 3.2 on sticky tires like Hoosiers can work for sure.
Me personally, I like to create rotation with the throttle as early as possible, so going too stiff in the rear might get in the way of that. But, lots of ways to skin this one, and that is what makes all of this so additive and fun!!!
Old Apr 13, 2019, 09:31 AM
  #494
kaj
kaj's Avatar
I'm picturing this
Old Apr 13, 2019, 09:39 AM
  #495
Veteran: Army
Dallas J's Avatar
Not quite what Marshal is *probably* eluding to. Make the rear do more work by taking a greater amount of the total weight transfer and the front has to do less work. Then do what you need to to keep the car stable. This has little to do with on throttle rotation and more about getting the front to turn and rear to yaw.
Evo's are a funny thing, lowering the car increases rear camber gain and decreases front. In something like an ASP/SM car, the rear might be so stiff its barely going to move so camber gain isn't seen so you need static camber. At the same time, RC's move at totally different rates so you may dump the rear ride height and leave the front high. Or you can jump to SM and just fix all that non-sense
Quick Reply: Sup w/them 2024 Summer Projects?
