Sup w/them 2024 Summer Projects?
Old Mar 13, 2023, 11:08 PM
  #5206
Ayoustin's Avatar
Originally Posted by kyoo
what area of the motor is the front case? is that the side all the belts are on (best I could google images it). i know the shop replaced all the seals when they did the job, so it's possible something didn't get tightened down fully as they did it. all these leaks are really wearing me down.
Yes, the side with the belts. The front case bolts onto the front of the block and has the oil pump and balance shafts in it. There are 4 shafts seals and 2 gaskets that all seal on it. But yea if you brought your car to them and they had it apart and it's leaking now then you should definitely have them take it back and fix their mistake.
Old Mar 14, 2023, 06:16 AM
  #5207
kyoo's Avatar
i think they will take it back.
furthering the narrowing process, one other symptom - it leaks without running. the car's been up in the air overnight, and i've wiped the floor down. i checked, new oil on the ground today. what else besides the oil pan holds/encounters oil enough when cold to leak? i'll hop back down under the car to look, but I'm surprised by that.
took a look - same spot as the picture previously, right around that metal hole by the oil pan. i would have thought it was the oil pan, if i didn't know it wasn't leaking previously.
Old Mar 14, 2023, 07:53 AM
  #5208
ViciousLSD's Avatar
the oil cooler drains back
Old Mar 14, 2023, 08:03 AM
  #5209
kyoo's Avatar
I dont tink that ould have come off with the head though would it
Old Mar 14, 2023, 08:39 AM
  #5210
Ayoustin's Avatar
In most cases the lines get in the way of removing the timing cover so it I'd imagine it was disconnected on the engine side.
Old Mar 14, 2023, 08:57 AM
  #5211
ViciousLSD's Avatar
oh i was just answering your question. well this why i keep everything OCD-level clean and dry and do the paper towels, oil drips just get passed around and slow to drip. if that leak starts from the VC then it will take a while for it to drip all the way down. maybe get yourself a sprayer and fill it with some degreaser. if your engine was clean you'd spot the leak easier
Old Mar 14, 2023, 08:59 AM
  #5212
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
Can you take a picture of where you're talking about? If its where I'm thinking it is, it's easy to have a leak there if the silicone is applied to the oil pan flange incorrectly.
Old Mar 14, 2023, 09:34 AM
  #5213
kyoo's Avatar
It didn't leak before engine job though, and the pan wasn't touched when they did the head, which is why I'm thinking it's something else that they did.
Old Mar 14, 2023, 09:44 AM
  #5214
ViciousLSD's Avatar
why is your axle wet? that could be flinging oil around
Old Mar 14, 2023, 09:45 AM
  #5215
kyoo's Avatar
it's prob getting dripped on. there's a fresh drop after the car's been sitting, so it's not the axle flinging onto the pan or w/e.
Old Mar 14, 2023, 10:03 AM
  #5216
ViciousLSD's Avatar
also check the underside of the manifold. lots of oil can stay suspended there
Old Mar 14, 2023, 10:43 AM
  #5217
That's not the spot I was referring to, so disregard my comment.
Only think I can think of having a leak there is possibly the mivec line (if the oil is coming from all the way up by the head). Still weird for it to leak when not running,
Old Mar 14, 2023, 10:51 AM
  #5218
kyoo's Avatar
maybe it was still winding down, i wiped everything down and put a towel down, let's see if it continues
Old Mar 14, 2023, 10:58 AM
  #5219
Bee-Raddd's Avatar
Check the dipstick tube and that the o ring is still there and seated properly. If they pulled the head chances are they had to disconnect this and remove it. Its easy for the o ring to slide up the tube or pinch as u press it in.
Other common places you can leak oil around the back would be the PCV Valve area. I doubt anything from the timing cover area would throw oil back here without it leaking down the timing cover side also. Id say its not a major leak but its flicking onto your CV and getting chucked around.
I dont recall any manifold bolts on that side going into an oil gallery but maybe somebody who has a head off could confirm. My spare head isnt at my place so cant look.
Old Mar 14, 2023, 11:13 AM
  #5220
Bee-Raddd's Avatar
So at the last competition round we really struggled with power in a straight line. It felt like the car was just off and wasnt making much power. We were getting our doors blown off by the big powered V8s in our class and made us a bit uncompetitive in the race as all our laptime was in the corners. I did a compression test etc to make sure the motor wasnt hurt and all came back fine so dropped the car off at the tuners to do some dyno running. He found a ignition lead was on its last legs so we replaced those with new ones. He optimized the ignition timing which seemed to be quite far out. made around 40 - 50hp more power in the mid range. Tuned up to 32psi and we are sitting at 680hp at the wheels which is plenty. G30-900 turbo on E85.
We wont run it on 32psi that will be more of a scramble boost setting if we need it but picking up that power in the mid range will definitely help and having the flexibility of picking different boost settings on the fly will definitely help. Wont be taking a knife to a gunfight this time.
The following 2 users liked this post by Bee-Raddd:
alpinaturbo (Mar 14, 2023), deylag (Mar 17, 2023)
Quick Reply: Sup w/them 2024 Summer Projects?
