Sup w/them 2024 Summer Projects?
ViciousLSD (Mar 26, 2024)
#5993
Popping out of only one gear is usually a bent shift fork but Jon would've caught that for sure. Did he tell you he found anything that was excessively worn? What was all replaced?
How many miles are on the car? I've seen popping out of gear due to worn out engine mounts, but that typically isn't just a single gear symptom. Giving the shifter cables a look over is worthwhile and so is checking the cables at the shifter itself.
#5994
57k miles on the car. it only happened in 2nd before this, but it's moving in 1st gear now too, but the way the momentum goes off throttle, 2nd is more likely to actually come out.
interesting about worn engine mounts.. actually now I'm wondering if it's related to this part: https://www.boostedfabrication.com/c...ly-crossmember ?
i'll also try shifter cable bushings and new trans bushings. shifter and cables seem fine
#5996
TRE def said they looked at everything, shouldn't be the trans.
#5998
we disconnected the cable while in second - it's tugging on the cable itself, so it's looking likely something internal that TRE missed?? not sure what else would cause that amount of pulling on the cable itself. they said it wasn't the shift fork but can't think of anything else it might be
on the 6 speed there is a small metal/rubber plug on the end of the trans... can you pop it off and look inside.. you should be able to see if the circlip holding the end bearing is propperly inserted into the bearing groove.... It is a long shot but I cant think of anything else..
