Sup w/them 2024 Summer Projects?
Old Nov 12, 2019, 08:03 PM
  #1096
Ayoustin's Avatar
+1 for Weir being hot garbage
What were you doing when it failed? Can't really tell you much without knowing that. I'd go used OEM of DSS if I needed an axle.
ViciousLSD (Nov 13, 2019)
Old Nov 13, 2019, 09:52 AM
  #1097
ViciousLSD's Avatar
This is during my 4th feathered autox launch with brand new 18" re71r's at the back. The car was already rolling. It even had enough momentum to take the car off course ~200ft. It felt like my diff exploded. I looked under the car to see if the casing was damaged and I saw fluid oozing . turns out the clamp on the inner boot broke too. the casing and gears look fine.
I'm waiting on TRE to call me back, ready to send my extra diff. meanwhile I'll try using OE plates on this unit
Old Nov 13, 2019, 02:05 PM
  #1098
Terror Rising's Avatar
What's the condition of the spare diff? I assume that all of this carnage didn't happen at the same time which would mean there was metal suspended in your oil and running through your bearings.
Old Nov 13, 2019, 04:53 PM
  #1099
Balrok's Avatar
Dang. Uh Houston, *pssshhh* We have a slight malfunction here.
I'm swapping out my Weir during the holiday break so I'll take photos of mine after 7 years of abuse. 0 launches however.
ViciousLSD (Nov 14, 2019)
Old Nov 13, 2019, 08:53 PM
  #1100
kaj
kaj's Avatar
Pics of my Weir experience, which they take no responsibility for, of course The basket had a number of cracks in it and couldn't be used. I had to buy an entirely different, used diff, to put together enough parts so Jon could build me something that worked LOL
ViciousLSD (Nov 15, 2019)
Old Nov 14, 2019, 10:08 AM
  #1101
Bee-Raddd's Avatar
Car starts and idles and you can drive it round the shop. couple things to sort out around the alternator not being told to charge and few bits of wiring to tidy up then tune today!
View this post on Instagram
Old Nov 14, 2019, 09:39 PM
  #1102
ViciousLSD's Avatar
just a used stock unopened one, which i will check out this weekend
Do we have any other option for LSD's? I dont think I have the patience to keep trying to reach TRE
Old Nov 14, 2019, 09:51 PM
  #1103
ViciousLSD's Avatar
we're kinda blessed/cursed with the availability of the Houston Police Academy concrete test track. I had 2 prior transmission repairs and I'm anxious to put my diff together to see if my trans is still ok I recently posted a pic of my cracked bell housing that was leaking fluid. I just got my car back from repairs, replaced the rear diff fluid but I dont recall seeing large metal chunks. just done 3 autox events since that day
Old Nov 15, 2019, 04:25 AM
  #1104
Ayoustin's Avatar
Yes, plenty of rear diff options. ATS, Cusco, Mfactory, OSG and probably a few more. It's front diffs where we tend to be more limited on options.
Old Nov 15, 2019, 09:45 AM
  #1105
Bee-Raddd's Avatar
So cars halfway tuned now. Got all the base stuff done. Sitting at 350kw on 20psi and the power curve is almost vertical so motor is healthy as hell.
Turned it off for the weekend and torqued the head all down and new rocker cover seals. Finish tune monday morning
The following 2 users liked this post by Bee-Raddd:
alpinaturbo (Nov 15, 2019), kaj (Nov 15, 2019)
Old Nov 20, 2019, 09:34 AM
  #1106
Bee-Raddd's Avatar
Place is dead again...
Got my car back from tuning last night, Haltech ECU is really good real easy to control and setup. easy to assign wires to sensors etc real user friendly. I thought it would take me a while to get used to after being a link customer for 8 years but nope.
Also looks like the haltech has much better control of the cars AFR's and boost vs the open loop boost on the link.
We ended up setting the spring pressure (18psi) at 375KW, Mid boost @24psi 435kw and overtake boost 28psi at 485kw.
So should be good to go!
Old Nov 20, 2019, 09:40 AM
  #1107
Ayoustin's Avatar
Are you running a 1500 or 2500?
Old Dec 6, 2019, 06:08 AM
  #1108
Having ankle surgery on Tuesday and waiting for the rest of my parts to arrive. A little bit of Christmas came early...
The following 2 users liked this post by Terror Rising:
alpinaturbo (Dec 6, 2019), EVO8LTW (Dec 6, 2019)
Old Dec 6, 2019, 06:48 AM
  #1109
Veteran: Army
Dallas J's Avatar
The difference your car is going to see next year is going to be crazy.
Old Dec 6, 2019, 06:52 AM
  #1110
kyoo's Avatar
we've come full circle
Quick Reply: Sup w/them 2024 Summer Projects?
