Modifications for STU
Old Sep 9, 2004 | 12:55 PM
  #31
jbrennen's Avatar
Originally Posted by DistantTea
We went over that time and time again on the scca forums. Changing your downpipe has been found to be perfectly legal by everyone who has a WRX. Its a disputed rule but the official consensus is that as long as you follow the highflow cat rule you can change out all other piping before and after the turbo.
You're talking about this thread?
http://www.sccaforums.com/ubb/ultima...p/topic/22/832
Still seems like a gray area to me. Especially for the Evo. A lot of the justification that they give seems to be that STX allows you to get rid of the precats on the WRX. Well, the Evo doesn't have precats, and you don't need to touch the downpipe to go to the "one high-flow cat within six inches of stock" configuration.
Go ahead and replace your downpipe in STU. Heck, you'll probably be fine. But I wouldn't go so far as to guarantee that you'd be safe from protest...
Old Sep 9, 2004 | 01:01 PM
  #32
JT-KGY's Avatar
I'm thinking about changing to a full 3" setup... dont think I can find a 2.5" to 3" high flow cat... and getting 2.5" cat + catback is a waste of time and money.
Old Sep 9, 2004 | 01:41 PM
  #33
chrisw's Avatar
The WRX was specifically allowed to replace the pre-cat. It's in a fast track I believe.
To clarify what you just said, it's OK to change all the piping on the exhaust side of the turbo.
I don't think the STU exhaust/cat rules are ambiguous when they apply to the EVO with the single CAT. As long as you retain the cat in it's stock location your good to go. If you want to take the conservative approach, just keep the stock cat in the stock location.
Old Sep 9, 2004 | 03:16 PM
  #34
tweekscratch's Avatar
Would it be legal to stay in STU after installing a "Vishnu Evo Stage 1 Standard" minus the cam gears and disabling the boost control on the XEDE?
Based on the discussion here so far it looks like this package would be legal as long as the cat stays within 6" of the stock one.
Is this a correct reading of the rules?
Old Sep 9, 2004 | 04:04 PM
  #35
ride22's Avatar
subscribing to thread
Construct
Jan 26, 2017 09:01 AM
Butt Dyno
Jan 11, 2016 10:06 AM
Butt Dyno
Jan 7, 2015 07:00 AM
TSL Rich
Apr 8, 2008 07:25 AM
porque
Aug 14, 2006 10:40 AM
