Bnib Dms 40mm(ma)
Bnib Dms 40mm(ma)
I have a set of brand New DMS 40MM CO's. Here is a description off their website.
Due to strong demand DMS introduced in 2003 the DMS Gold, 40mm performance street range of shock absorbers.
This is a bump/rebound adjustable shock with a wide, useable range of adjustment giving users 30 settings allowing for all applications, from comfortable touring to club motor sport.
DMS Gold 40mm adjustable shock absorber is made for a wide range of vehicles, including Subaru Impreza, Mitsubishi Lancer, Mirage, VW and many others. Check our website catalogue or with your DMS distributor for shocks for your car.
DMS Gold 40mm shock absorbers have high flow piston ports giving this shock superior control allowing more precise tuning.
Consult your DMS dealer on other parts which will help get the best from your DMS Gold 40mm Shocks. These may include sports shock and suspension mounts. These products are available for most performance cars. (Some stock suspension bushes allow excessive suspension movement not controlled by the shock or spring.)
Product Description:
DMS blue shell case. Made of chrome-moly high strength steel. Fitted with adjustable anodised aluminium spring seat and lock nut. The DMS 40mm strut body is fitted with double lipped seals at the top, special low friction bushes and a seal below bottom bush to eliminate stiction. DMS uses specially formulated grease which gives durability and longevity to the 40mm GOLD suspension
Adjustable camber available on mounting brackets.
40mm shock absorber insert with high flow competition design piston with 30 defined adjustable bump and rebound settings.
DMS only use special formulated racing shock absorber fluid in this street performance product.
Shocks Taken out for picture purposes only. Selling to try to fund a motor build.
Retail is 2800. I am entertaining offers.
Jason
Jason
zbomb
32
May 9, 2016 01:09 PM
Kami Speed
EvoX 'For Sale' Suspension / Brakes / Handling
110
Jan 23, 2015 02:38 PM
Kami Speed
Evo 'For Sale' Suspension / Brakes / Handling
116
Jul 6, 2014 11:36 AM
porsherules911
Mar 21, 2011 09:57 AM
ForcedFedRS
44
Sep 19, 2008 05:40 AM
