FS: complete GT35R turbo kit
I have for sale a complete custom built 35r turbo kit for an EVO 8 or 9, comes with the following:
Precision dual BB gt35r turbo w/.63 5-bolt hotside & .70 AR impeller & bullet ported anti-surge housing
4" intake with coupler to fit stock MAF
V-Banded full 3" downpipe w/flex section, will bolt to stock cat or any 2-bolt aftermarket exhaust
heavy gauge short runner exhaust manifold w/modified stock heat shield
LICP to mount to stock IC
tail 38mm WG re-routed back into DP for stealthy operation
all oil & coolant lines to bolt up to the factory stuff just like the stock turbo
All exhaust parts have been gasket matched and coated. I designed everything to be an easy bolt in affair which won't take more then a couple hours to install in your garage.
Here are some pics after everything came back from paint, excuse the color of the photos, something was up with my camera at the time these were taken. These are just mocked up shots with everything put together, the compressor obviously isn't clocked in the right position.
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r004.jpg)
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r010.jpg)
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r006.jpg)
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r011.jpg)
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r014.jpg)
Here is a comparison of a normal t3 inlet next to the gasket matched inlet.
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r001.jpg)
you can see in these two pics how much material was actual removed.
BEFORE:
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r020.jpg)
AFTER:
![](http://i166.photobucket.com/albums/u95/alwaysinboost/evo%2035r/EVO35r016.jpg)
No other parts to purchase or modifications needed to install this kit, it will work with the stock radiator and exhaust. There are lots of other little 'trick' mods done to make the kit easy to install and also function better. Looking for $2,900 for everything. Located near Phila and have many references if needed. prefer a local sale.
BEFORE:
AFTER:
AlwaysinBoost
For Sale - Wheels / Tires
35
Jun 21, 2013 04:26 PM
AlwaysinBoost
For Sale - Miscellaneous Automotive
Jan 27, 2012 11:29 AM
AlwaysinBoost
72
Nov 6, 2010 08:43 AM
