Camber Toe (Lynbrook, NY) - review
Just got back from Camber Toe in Lynbrook, NY (Nassau County) and had them align the Evo. Ryan was able to fit me in at the end of the day and the customer service was fantastic.
Sing had looked over my car, asked me if I had any specifics I wanted done and we discussed what I used the car for and he made some suggestions. He talked to me about the effects the camber, toe and caster had on the car before and while working on the car to make sure I understood what was being done. After completion Sing took the car out for a spin to make sure everything was tight and the job was done properly.
Very courteous and professional guys and was very happy with the work performed.
If you are around the Lynbrook area and are looking for an alignment or tires mounted and balanced you should look into Camber Toe:
659 Merrick Rd
Lynbrook, NY
(516) 872-6400
659 Merrick Rd
Lynbrook, NY
(516) 872-6400
The car is mostly on the street with the ocassional trip to the drag strip once or twice a month. I went with:
-0.8 camber (all around)
-0.1 front toe
+0.1 rear toe
I'll revisit how aggressive I really need to be after a few passes down the track. Sadly this is the first time I'm trying to dial-in the suspension on the car so I'm sure I'll make some future changes depending on tire choice and what not.
-0.1 front toe
+0.1 rear toe
no experience with them, but when I read the title of this thread I could have swore it said Camel Toe Review... needless to say I was disapointed to come in here and see no pics.
they are slightly more expensive then regular alignment places , but they do good work. i have had alignment done on a evo 9 with blistein hds, and swift springs. clean shop as well. going back to get realignment after installing stance ss+. debating if i should have corner balance done. this is a dd car. any one have corner balance done with coilovers? any difference in dd?
