Need knock setting adjustment
Old Aug 8, 2017 | 02:17 PM
2rbolag's Avatar
My balance shaft delete causes plenty of rattle and vibration which are triggering phantom knock. I've done wot pull in 4th and get 0 knock count. But low load in 1-2-3 I get some count. High load I get none. I can free revand get no knock, my plugs are at .22 and the sensor isnt the issue. I know it's phantom knock. I need the help of someone to tweak my knock settings and disable egr. I can travel within NJ, NY & CT.
Pm your price
Thank you
Old Aug 8, 2017 | 02:40 PM
ronaldo9's Avatar
If you are on tephra and have a cable, ecuflash, evoscan, I can walk you through disabling egr and tweaking the knock settings. I am in NJ and have an evo 8.
Old Sep 5, 2017 | 01:06 AM
2rbolag's Avatar
Unfortunately, I don't have a tactrix cable nor evoscan/mitsulogger. Need some adjustments to my ecu. Don't need a tune just need to disable EGR, adjust knock load to be less sensitive (I have balance shaft delete and get phantom knock from 2k-4k rpm) and raise the stock boost cut load (225%) via ecuflash.
You able to help out? I can come to you. What do you charge?
Old Sep 5, 2017 | 06:43 AM
ronaldo9's Avatar
I would not charge for this... it's easy to do and takes minutes. Will need to know what rom you are on so I can download the correct xml for your car. Hopefully your rom isn't locked if you are tuned. Otherwise you will have to consult your previous tuner.
Old Sep 5, 2017 | 07:57 AM
4b11slayer's Avatar
I would ignore knock compelty before 200 load.
You need a tactrix and a laptop w ecuflash regardless.
Or you pay a tuner.
Old Sep 5, 2017 | 11:21 AM
2rbolag's Avatar
The car was previously tuned on a Cobb AP but I've ditched it since then. Is there another way of finding my rom without a tactrix cable?
maxspeed96ct
Sep 4, 2016 06:50 AM
thedru13
Nov 3, 2014 09:58 AM
Crester
Nov 17, 2010 09:09 AM
ROK EVO
Dec 18, 2007 10:46 AM
sevensign
Oct 17, 2003 08:28 AM
