Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
A beeping noise
Old Feb 5, 2006 | 05:15 PM
miked420's Avatar
A beeping noise
ok so i have a injen intake and ic kit. im running 21psi and last night my lower ic pipe blew off from the intercooler. to make a long story short i had to get a tow home and take the bumper back off and put it all back together. when i started my car back up the check engine light came on. so do u think that i can just reset it or could there be something wrong. the car idled fine and started fine so i was thinking that it just came on b/c i drove a little ways to pull over before turning the car off. also ever since i did a ECU reflash my car has made a beeping noise. its not inside the cab its inside the engine bay and im not sure what the hell it is. nothing seems to be wrong everything works, but i was just wondering your guys opinion on this. THANKS
Old Feb 5, 2006 | 05:16 PM
miked420's Avatar
also its only around like 1500 RPMS when im coming down to an idle. and its only one beep. it doesnt beep over and over.
Old Feb 5, 2006 | 05:19 PM
smokedmustang's Avatar
Unplug the battery "Negative" terminal for few minutes, and reconnect(resets everything). The SES light should go off. Who did the "flash"? I don't know what that could be.
Old Feb 5, 2006 | 07:03 PM
mikiblueeyes's Avatar
Evo is a HIGH tech car, and therefore beeps
Old Feb 5, 2006 | 07:25 PM
Evoryder's Avatar
somebody is tracking your moves
Old Feb 6, 2006 | 09:08 AM
timmy_g83's Avatar
what BOv are you running???? I just installed a new one and blew the pipe off....bov was set too high. I get a clicking noise out of mine but I think it has to do with my boost controller....very annoying but **** it
Old Feb 6, 2006 | 09:24 AM
miked420's Avatar
thanks, it might be the bov now that i think about it. im running a greddy RS. i have played with it for a while. the sre shifts fine and it doesnt fluter. it holds to 21psi fine. and even at 5or 10 psi it blows. sometimes it fluters when im at like 0 or 2 psi so im not sure. i think that i will just put the stock one back in for now. i have read that it will hole up to 22psi is thiat true. let me know thanks a lot.
Old Feb 6, 2006 | 02:45 PM
ashumo's Avatar
sometimes when im sitting there @ idle at a stop light or drive thru i swear i hear a beeping noise. then again im an mechanic in the coast guard and loud engine rooms have my hearing all screwed.
Old Feb 6, 2006 | 03:03 PM
coco's Avatar
no seatbelt on
sorry but that was the only beep I have heard in my car
Old Feb 6, 2006 | 04:05 PM
evo-boy's Avatar
its proly your clucth harmonics ever scince i got a new mitsu clutch it makes some harmonic noises when slow in nuetral over an uneven road
Old Feb 6, 2006 | 06:03 PM
Evoryder's Avatar
...can't be the seatbelt...he wouldn't be that...
...could he?
Old Feb 7, 2006 | 10:34 AM
miked420's Avatar
its not the seatbelt its out side the car i can only hear it when i have the dorr open or the window down and no music on.
Ralliart_on_LSD
Lancer Engine Tech
19
Jan 23, 2011 12:47 PM
Aven
Aug 21, 2009 11:06 PM
R0ME0
Jun 17, 2009 11:07 AM
bboy_RES
Jan 29, 2008 08:03 AM
Nosaj$$MR
Aug 24, 2006 08:32 PM
Quick Reply: A beeping noise
