Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
TorqueFreaks does 669HP on stock 4g63 block
Old Mar 27, 2007, 03:53 PM
Torquefreak1's Avatar
This is another (Different Car) Evo 9 SE stock block pull
34 lbs of boost
50 shot for spool
Mod list
Same as other car but utilizing NOS from 3lbs to 14lbs for spool up (again controlled through the AEM EMS)… This car has been terrorizing the streets for about a month and still kicking. To say this car are been driven hard is an understatement. The owner burned through a set of tires and brakes in under 5k on the car.
Attached Thumbnails TorqueFreaks does 669HP on stock 4g63 block-585-nother9.jpg
Old Mar 27, 2007, 04:08 PM
Kyle R's Avatar
Please do. I'd like to take a look.
Originally Posted by Torquefreak1
Our customer stated that it was ok to go ahead and forge into uncharted territory to break the "stock block" record. If there is enough intrest I will post up the AEM log
Old Mar 27, 2007, 04:11 PM
Vishnu_Evo8's Avatar
my christ!!! I really want to know how long this lasts.. It wont suprise me if it keeps goin for a while. Good luck
Old Mar 27, 2007, 04:21 PM
Paul Nelson's Avatar
Originally Posted by TFJasonO
I'll get right on that Don't worry we will leave your record alone for now!!!
I feel the iceyhotstunzas need some love
Old Mar 27, 2007, 04:38 PM
Here you go. Note that the max knock is 1.7 volts. Another important note is that past experience with the stock Evo knock sensors with AEM equipped cars leads to quite a bit of erroneous knock noise that is shown. We use another make of knock sensor that allows a greater degree of accuracy tuning Evos. I'm sure other high level tuners can attest to this trouble with the stock evo knock sensors. With the OEM ecu/reflash they work fine however.
Note: sorry for the image not being the greatest. Gotta love the file size caps
Attached Thumbnails TorqueFreaks does 669HP on stock 4g63 block-669_aemlog.gif
Old Mar 27, 2007, 04:50 PM
evo_08's Avatar
sean ivey made 612whp on boost on a stock block.
EvoDan2004's Avatar
Originally Posted by evodan2004
what is the week point on the stock block and what is most commenly known to make it go??
anyone?
Old Mar 27, 2007, 04:51 PM
evo_08's Avatar
rod bolts
Old Mar 27, 2007, 04:59 PM
BrewPuBeaver's Avatar
34 lbs of boost
50 shot for spool
Mod list
what fuel was this pull done on, if you recall
Old Mar 27, 2007, 05:25 PM
TFJasonO's Avatar
k&S 114 octane
Old Mar 27, 2007, 05:44 PM
EVOGOD21's Avatar
the evo 9 is something ealse! good numbers, and I bet you this guy did not spended 30k dollars!
Old Mar 27, 2007, 09:12 PM
cant delete double post?
i am the first one to admit that the EVO is a better platform to work with than the STi for raw power, this is no secret.
Old Mar 27, 2007, 10:15 PM
dustin03's Avatar
what know sensor did you use?
Old Mar 27, 2007, 10:28 PM
TFJasonO's Avatar
The Knock sensor kit utilizes a modified Subaru sensor.
Quick Reply: TorqueFreaks does 669HP on stock 4g63 block
