E85 11.2@121 stock '04 turbo SSL
#47
I've got a question for you guys running E85. How are you going to address the long term issues of E85. ...for example, how it likes to draw water and the eventual build up of water in the fuel system
#48
Well water mixes with E85/E98 so if you run it you should not have a problem unless you let it sit for a long time. I know you can mix upto 30% water and the car will still run. Not good for tuning though.
I think the fuel would have to sit for quite sometime to collect enough water to cause a problem. If you run atleast 1 tank a month you should be fine.
Paul Nelson
32
Oct 21, 2014 01:37 PM
Lucas English
Aug 8, 2007 09:26 PM
