Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Pina motorsports
Old Jul 7, 2007, 02:25 AM
  #46
Lucas English's Avatar
I would try dropping the plug gap down to a .024 with a feeler gauge and don't touch the electrode part much if you can help it.
Stock turbos will spike quite bad if you are trying to hold higher boost in the upper RPM's.
Creep from WG will be a progressive thing that will go higher and higher with RPM.
Old Jul 7, 2007, 10:14 AM
  #47
Clos23's Avatar
^Do you think I should invest in say a forge wg actuator?
Old Jul 7, 2007, 11:43 AM
  #48
hanahawaiian's Avatar
I think John B have Forge WG on his Evo..
Forge and JUN sell Evo WG for IX and VIII
Old Jul 7, 2007, 11:58 AM
  #49
I know an up graded actuator will help a ton with tapper which means you wont have to run such a big spike to keep the boost up till red line. My car has a FP actuator. The Forge looks like a nice peace but have no personal data feed back about it.
Old Jul 7, 2007, 02:10 PM
  #50
Kevindanger's Avatar
But Jb has a Green and was running race gas
Old Jul 7, 2007, 04:39 PM
  #51
uglyevo's Avatar
I have the fp actuator as well
Old Jul 7, 2007, 04:46 PM
  #52
Clos23's Avatar
Originally Posted by hanahawaiian
carlos maybe need 02 housing!
Uhh, I already have one, you know chris.
Old Jul 7, 2007, 04:48 PM
  #53
Clos23's Avatar
Is there any way to control boost spikes, say through the ecu? I set my ebc for a certain boost, yet it still wants to climb, problem seems to be only in 5th gear and for some reason 4th gear during the dyno day lol.
Old Jul 7, 2007, 05:07 PM
  #54
uglyevo's Avatar
try turning the boost down some. have you messed with the gain or the set gain on the ebc?
Old Jul 7, 2007, 05:10 PM
  #55
Clos23's Avatar
Nope, only thing I've touched is actual boost setting, and the warning/boost limiter. Boost was set to the same as the last dyno day, 23.5psi.
Old Jul 7, 2007, 05:13 PM
  #56
uglyevo's Avatar
what ebc do you have? you may need to adjust the settings
Old Jul 7, 2007, 05:17 PM
  #57
Clos23's Avatar
blitz sbc id-III
Old Jul 7, 2007, 05:28 PM
  #58
uglyevo's Avatar
do you have the manual for it? should tell you what to mess around with to eliminate the spike. i have the greddy and its the gain and set gain, not sure about the blitz
Old Jul 7, 2007, 05:52 PM
  #59
Clos23's Avatar
Okay, I looked at the manual just saw how to adjust the gain settings. I'll have to wait till I come back from Korea to see if I can figure it out. As far as your FP wga, did you notice any postitive differences?
Old Jul 7, 2007, 07:41 PM
  #60
codgi's Avatar
The ECU can control the stock BCS system. When you install an EBC you eliminate that system all together.
Quick Reply: Pina motorsports
