400whp+ or BUST
400whp+ or BUST
Hey guys..
I want to push more power and WHP on stock IX turbo,
I recently made 374whp, check thread on https://www.evolutionm.net/forums/sh...d.php?t=340461
Im think dont want use Meth kits sooner.. i want true WHP on Pump gas..
Im think i missed something out?
should i get???
Ported intake and bigger throttle body?
Upgrade Fuel Injectors? 680cc to 1000cc?
ETS UCIP with Mini battery kits (since im rid fujita intake/ucip combo)
TIAL BOV
COP or ingition (spark tech, HKS or sun automotive force)
something.. and give me ur shouts and options
should i get???
TIAL BOV
Hey guys..
should i get???
TIAL 38mm BOV
should i get???
TIAL 38mm BOV
Do you think WHP from Meth is fake? You can just say you want more whp
without using meth.
No point in getting injectors, you're not even maxing out the ones you have at the moment.
The Mini battery kit won't help you on your quest for more hp...
A TIAL 38mm BOV??? >___> you mean wastegate?
The other mods might help but won't net you the 26whp you're in search of.
without using meth.
The other mods might help but won't net you the 26whp your in search of.
without using meth.
i mean Im rid my Fujita Intake and UCIP.. too air flow resist on fujita intake so i want ETS one with Stright pipe way... i hope u understand what im say?
actually i dont want any mix any meth or racing gas. i just want see pump gas can push more power from stock then ill use C16 and Meth is my last thoughts.
Honestly, you have like every single bolt on possible and then some, you should be above that whp on a dynojet. DriftOffice's reads high.
You already have a Upper pipe, why pay money for another one? Use that money for a Meth kit and tune.
pretty sure you meant Wastegate (external). Tial doesn't make "sizes" for their BOVs in 38 and 44mm's. Only their wastegates.
a 50mm external wastegate spring would be insane, like it would hold 30psi on just spring o___o
Im not going do any racegas or meth for now.. i want test pump gas.. Aaron n lucas will help me out and figure out..
before i go transplant to full built and 3076 HTA turbo upgrade (30R)
yes i know what is BOV and WG. i mistake put 38mm instead 50mm
38mm WG i mean 50mm BOV
I already know you guys are going to pull the "he's deaf card." Don't.
If you keep insisting on keeping the training wheels on he will never be able to ride on his own.
so i could be mistake.. i can learn something new everyday.. no one is perfect.. i like to learn and share infos and experinces..
also Lucas n Aaron will work on my timing map and re do and make my Tq better and hp more
