Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Emissions FTL?
Old May 12, 2008, 01:24 PM
tyre11c0rp's Avatar
Emissions FTL?
hey all
got some work done to my 06 / IX SE, and am now catless. What are the laws in Seattle?
- when is the first time I have to do emissions?
- can I be issued a 'fix it' ticket for cat-less, while simply driving around? or only at emissions testing.
- what methods do people use to pass emissions (change registered address? or as long as the computer reports 'ok', they won't check for a cat?)? Currently registered to my downtown seattle address.
- i have no resonator / 2nd muffler.. so it's damn loud. I only say this because it's going to make people want to punish me
thanks all for the thoughts
Old May 12, 2008, 02:23 PM
raiceboi697's Avatar
if you dont throw a code then you are good to go
Old May 12, 2008, 02:29 PM
tyre11c0rp's Avatar
so... even if I drive in the the emissions station and it's deafening... if I don't throw a CEL I'm good?
great news, thx for the reply
Old May 12, 2008, 02:30 PM
Psquared's Avatar
It doesn't matter if you are in seattle or miami. Altering a vehicles emissions control devices falls under Federal law.
That being said...and don't quote me on that....emissions laws vary by state/city. If you don't have an inspection in your area, you may be fine. Except for the possible cop that may want to harass you.
Old May 12, 2008, 02:32 PM
Psquared's Avatar
Im not sure about your area....but in NC, altering a vehicles exhaust that makes it any bit louder than stock....potentially could yield you a ticket.
Old May 12, 2008, 02:39 PM
20gmr's Avatar
Emmisions laws are both federal and state i beleive. In pa it actually varies from what county you live in. Up here at school they only do a visual inspection. but my home county where i am registered they plug into the obdii port and make sure the monitors have ran. I use a mechanical o2 fix so that car thinks there is a cat. The inspection station tried to give me **** about not having a cat but since my car is above 1996 they are not required to do a visual inspection. hope that helps
Old May 12, 2008, 02:45 PM
Jorda420's Avatar
get an perrin o2 simulator call it good. Make friends with the inspector or watch him/her do the inspection and keep them busy so they dont look under the car! heheheh!
Billy@EnglishRacing's Avatar
dont tell the cop you dont have a cat and you will be fine.
As for passing emissions you should be fine, but emissions are lame, i stopped getting them
Old May 12, 2008, 02:52 PM
Sky Evo X's Avatar
Originally Posted by tyre11c0rp
hey all
The 5th year of your purchase date if the car is new. I think its 2011 for you.
You can if they can prove it somehow, but I doubt it unless you devulge the info.
If your car is registered in a zip code where they are emission exempt you don't have to take them.
http://www.ecy.wa.gov/programs/air/pdfs/Zip_codes07.pdf
WA state has a RCW where you cannot modify the muffler. If you get pulled over you will probably eat a ticket.
I just googled all the info for you since no one was actually answering your questions.
http://www.ecy.wa.gov/programs/air/C...tive_Pages.htm
Old May 12, 2008, 02:55 PM
rcheung's Avatar
hey all
I dont know about a fix it ticket but no cat is like a 2500 dollar ticket.
Old May 12, 2008, 03:38 PM
tyre11c0rp's Avatar
Great stuff, sky.
Sum: before 2010, register in a zip that doesn't require testing.
Old May 12, 2008, 05:38 PM
evo_k's Avatar
As long as you still have the 2nd O2, and just clear all the codes, then it should be good since they are only plugging into the ECU via OBD2 to do the test.
They also only do idling test, so exhaust noise shouldnt be a problem. Maybe you can add a silencer to temporarily quiet the car down during the test just for the sake of it?
Old May 12, 2008, 06:46 PM
hanahawaiian's Avatar
dont worry
I dont have Cat my full straight TBE and one muffler.. no cop trouble.... for 2 years
Old May 12, 2008, 10:25 PM
importjake00's Avatar
Originally Posted by hanahawaiian
dont worry
No. You just get outta every damn ticket!
Old May 12, 2008, 10:44 PM
i got trouble for speed that all
Quick Reply: Emissions FTL?
