Wheel Spacers
Wheel Spacers
Anyone know of a place in the Auburn area which sells high quality wheel spacers? Just received my RPF1s in and I'm in need of a 2 or 3mm spacer to clear the front brakes. Need these ASAP for the autox this weekend. I've already heard Intec and Illtech may have them in, but they're not open yet and I'd like to get as many places on my list to call as I can. Also, if anyone has a set they'd be willing to sell then hit me up as well.
Thanks,
James
541.914.1621
Thanks,
James
541.914.1621
if you had 20mm spacers on the rear you would rub pretty bad with OEM rims (from my understanding on the subject).
Seems like the max you can run on OEM and without fender modification (as your short on time) is 20mm up front, 15mm out back.
he planned on bolt on spacers but with what were working out the tires would rub on the fender wells
the 22 offset would have been perfect for that wheel but were figuring it out now and working on everything
as does intec racing in kent
IMO spacers suck, they put a ton of stress on the hub. the bolt on spacers are ok they act as if wheels were on there with a higher offset
get the right offset and dont worry about spacers period. The rpf 1's have a different face that doesnt give depth on the wheel hence the face hitting the stock calipers
mrfred
14
Jan 13, 2015 05:30 PM
theEVOdream
20
Jun 11, 2012 12:14 PM
06redrocket
10
Mar 8, 2011 06:45 PM
DefBringer
Aug 5, 2010 01:02 PM
