Problems?
Problems?
I think I may have problems. A few months ago I got an Apex Power FC with Power Commander (monitor displaying engine data) put in. I've been paying attention to knock levels. My tuner said that if I get over 30-40 to let him know. Usually I don't get above 20, but for the most part I drive pretty consevatively. However, I was on 405 and an sr20 240 pulled up next to me and dropped a gear. Hell, can't pass that up. I get on it and making shifts around 7-7.5k.. that's as high as I usually push it atm. We make a few pulls and I check my knock and it says the highest recorded was 81? wtf. I didn't hear anything, some bad smells coming from our cars but I don't have a cat and i'm sure he didn't. Drove another 30 minutes home and the car seemed to be fine, all the other numbers looked fine and so did my temp. Another problem I have is a strange squeaking/chirping type thing going on near the cams. Might be normal but It doesn't sound like it would be. My car has 64k miles, I'm about to drop some more money on some other mods but want to make sure I don't need to replace other things. Suggestions?
Sounds like you should contact your tuner.
Other than the squeaking/chirping sound you talk of, I wouldn't worry too much. My car registers a bit of knock on occasion in top gear at WOT.
Yeah, will do. It's like a whirling noise, kind of loud and high pitched. When the car is running and I"m parked I hear it and then when I turn the car off it's the last sound I hear. May just be normal, my car seems to run great. I don't understand knock too well. It's the first time I've seen my car above 30 knock though, so hopefully it's nothing. I think that if it really was at 81 knock then I would've felt something, that would damage my engine wouldn't it?
I dunno how the PowerFC registers knock, but the stock ECU on my car is very unhappy with 8 counts of knock.
Prolonged knock is never good, a bit here and there isn't too bad AFAIK, but I am no pro.
My advice for the sound is find someone local to you who is not new to the Evo, and have them listen and ride in your car.
If it's cumulative knock over an ignition session that might not be too bad depending on the amount of time it's logged, but if you get 81 counts of true knock on one WOT race, that is horrible. I have my knock light set up for 3 and 6 counts of knock, and hardly ever see it go off.
I've actually heard of that sound before from a friend. He took it to Road Race Engineering and they figured it out for him... It was something to do with the MIVEC I believe... try giving them a call.
Ah I don't have mivec though. Mine's an 05. Oh, ten to one? That would be great if that's the case. Haha.
8? I don't think 8 is much to worry about. I've been reading that the Power FC records knock differently and can be inaccurate. Especially if the car is modified, it's really sensitive. It's mainly stuff I've read online, can't really trust all the Bro-Science. I just dropped way too much money on ordering new parts. baha.
Accurate tuning and monitoring will be a prudent investment.
I think the 3-bar MAP sensor from English Racing is about $150ish? and tuning. Would be cheaper and more effecient than random parts. (and probably quite a bit cheaper than the PFC was in the first place)
8 counts of knock is no good...but realistically not that bad. Not uncommon to see spikes when going into 5th or 6th sometimes. You would be pulling 2-3* of timing though which doesn't help power. Any particular reason running the Power FC though? They aren't bad by any means but being what Ecuflash is able to accomplish and the amount of support for it and available tuners it would be easier to get your tune dialed in better. Seeing as one of the better local tuners in the area is quite known in these parts you might be able to sell the Apexi unit and get a better tune and have money left over...just my thought
