Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Has anyone tried both Brad Penn and AMSOIL in their car personally?
Old Feb 8, 2011 | 10:42 AM
Rxracer's Avatar
Originally Posted by drocksmash
Lol no it is something mechanical, a sort of pop noise when taking a slight turn/bump
happens more often on cold start/rainy days
very inconsistent.... but happened a good 6 times in a row the other day.
cv joints look clean
Most often from front right wheel well, but sometimes seems to be coming from others?
Time to sell it and buy a new X
Mine was doing this on the cold days here in Prosser this winter. turns out it was the springs and struts. i had those crappy green springs (tien) on stock struts, and it would hammer on cold mornings.
I changed to a set of MR struts and springs, and its all better here.
might want to look into that.
Rob
Old Feb 8, 2011 | 10:55 AM
daishi77's Avatar
i just put the Valvaline VR1 (20w-50) for my car and i noticed a big difference from the synthetic. Plus if you are running Fp Black/newer red they highly suggest noe that you run oils with high zinc content in them. they just posted a Pdf of what you shuold use due to the way they made their turbo's. This was put out in oct '10 so pretty recent. I'm going to try some amsoil next since Parts Plus just started selling the full line up here in oak harbor.
Old Feb 8, 2011 | 12:33 PM
Ryan.Kauz's Avatar
back on topic: Amsoil has a high zinc formula which is what I, and Joey B are running.
I cant compare it to Sean Penn's oil, but I can tell you the Amsoil made the engine run VERY smooth. LMK if you want to give it a shot and i'll help you out.
http://www.amsoil.com/StoreFront/aro.aspx
"PRODUCT DESCRIPTION
AMSOIL Synthetic 20W-50 Motor Oil is specially formulated to provide superior protection and performance in a wide variety of demanding applications. By incorporating high-quality synthetic base stocks and a superior high-zinc additive package, "
"Provides Superior Wear Protection
AMSOIL Synthetic 20W-50 Premium Protection Motor Oil is a high viscosity oil engineered to protect against metal-to-metal contact. It resists viscosity shear and is formulated with a heavy treatment of zinc and other anti-wear additives for excellent protection of gears, bearings, cam lobes and other high-pressure components in engines and transmissions. AMSOIL Premium Protection Synthetic Motor Oil helps extend engine life."
Old Feb 8, 2011 | 01:22 PM
WarmMilk's Avatar
why do you guys run such a heavy weight oil? especially in the winter?
do any of you get the oil lab tested (such as blackstone) after use?
Old Feb 8, 2011 | 02:43 PM
DKC6691's Avatar
I run 20-50 all year around but that's also because if you are not using balance shafts and have a built motor that is usually the oil that is reccomended.
Old Feb 8, 2011 | 08:10 PM
03Evo8DTC's Avatar
BTW brad penn is 47.50 for 12 qts at honest performance in fed way
Old Feb 8, 2011 | 10:31 PM
BuiltS13's Avatar
Do you have coilovers?
Old Feb 8, 2011 | 11:02 PM
WarmMilk's Avatar
ah, I see... I have a 10, so I never really researched the whole balance shaft thing...
Old Feb 8, 2011 | 11:40 PM
BuiltS13's Avatar
FYI Brad penn looks really cool when your dipstick blows out on the dyno... Looks like ghost busters came and shot up the Slimer under the hood lol
Old Feb 9, 2011 | 12:06 AM
Aaron20's Avatar
lol
Old Feb 9, 2011 | 05:50 AM
drocksmash's Avatar
pretty sure the whole suspension is stock
Old Feb 9, 2011 | 07:33 AM
DKC6691's Avatar
Did you have a catch can? If you need on of those retaining springs I think ive got one somewere you can have.
Old Feb 9, 2011 | 11:15 AM
Rxracer's Avatar
that is a really good price, i was thinking of moving to brad penn oil, but no one around here carries it local.. maybe next time i make a trip to seattle ill pick up a case or two.
so anyone have a preference on filters? usally i use the mobile 1 filter....
Old Feb 9, 2011 | 02:17 PM
nollij's Avatar
NAPA Gold Oil Filter is ~$6 and just as good as Mobil 1. It is a Wix filter.
Part number is FIL 7092
Old Feb 9, 2011 | 03:32 PM
yahu's Avatar
good price! That is what you can find online usually. I'll have to do that going forward.
This
LMAO!
I usually use the OE filter. They are like $5 with a crush washer I think?
Quick Reply: Has anyone tried both Brad Penn and AMSOIL in their car personally?
