Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
CF Hood Help
Old Mar 31, 2011, 11:30 AM
lancerstud2008's Avatar
CF Hood Help
I've got a guy that wants to trade his CF X Hood for my stock hood, only issue is that there are no washer nozzle holes drilled.
Is there a local shop you guys would trust to drill in the CF and install them?
Old Mar 31, 2011, 11:36 AM
nucci's Avatar
(My day job involves machining carbon fiber on CNC machines)
I would do it myself using the appropriate sized carbide drill bit and some water for coolant. Put the water in a spray bottle, and apply blue 3M painters tape to both sides of where the hole is to be drilled. Mark, drill, remove tape and deburr with a bit of fine sandpaper. Done
McMaster Carr would be a good easy source for carbide drill bits if you don't want to try to find them locally (I just order from McMaster since I'm lazy).
Matt
Old Mar 31, 2011, 05:49 PM
Other than doing it myself is there a shop that would do it? I called Belkirk and they said no.
Old Mar 31, 2011, 08:57 PM
*.jdmevo8.*'s Avatar
Just do it yourself Justin. It's free
Old Mar 31, 2011, 08:59 PM
Or u can just not use the washer nozzle u don't need it. Summer is comin soon and when it rains u won't use it
Old Mar 31, 2011, 10:27 PM
I'm gonna kick your ***
Old Mar 31, 2011, 11:07 PM
BuiltS13's Avatar
Do you really use the washer nozzles that often? lol I don't think ive used them more then a hand full of times in the 8 years ive been driving. Just pay some bums to wash your windows once and awhile.
Old Mar 31, 2011, 11:15 PM
I guess i'll go with no nozzles for now and see how it goes lol
Old Apr 1, 2011, 12:24 AM
jnut24's Avatar
Dremel it!
Old Apr 1, 2011, 07:09 AM
D Grade's Avatar
Come down to Lacey, Justin. Ill do it for you.
Old Apr 1, 2011, 07:21 AM
F0RSAKEN's Avatar
You gonna wash his nozzle, or drill his hood so the nozzle can be inserted?
Old Apr 1, 2011, 08:33 AM
D Grade's Avatar
Justin is gonna have to wash his nozzle before any insertion.....wait...what???
Old Apr 1, 2011, 09:01 AM
js06evoix's Avatar
I hope the CF hood isn't a Seibon... they suck. Mine cracked and so has several others that I know of. I have to replace mine with something else. :-\
Let me see pics of it once you have it on your RA... I'll be curious to see if I want to do that for my girl's SB RA.
Old Apr 1, 2011, 09:06 AM
RiG
RiG's Avatar
Get the washers that attach to the wipers like on some of the GM cars. Get rid of the ones on the hood, it looks cleaner and you wouldnt have to drill into the hood.
Edit: Also, I would stick with the stock hood, its pretty light already. I had a CF hood on my Talon and I got tired of it and went back to stock.
Old Apr 1, 2011, 09:42 AM
This is said hood.
http://www.autocityimports.com/2008-...od-p-8306.html
Quick Reply: CF Hood Help
