Ok, dropped my X, making a clanking noise..
So I just dropped my car, using the Tien S Tech. I am driving down the road and start to hear clanging from the rear, not consistent either like when I hit bumps, just kind of random, but obviously only when the car is in motion. My question is, with these springs, anyone know if the bump stops need to be cut or can they remain stock? I know we cut them, but just wondering if we should have left them? Any experience with this or suggestions, would be appreciated.
Ricky
Ricky
if you cut the bump stops too much it may be the problem. does it sound like an expensive clunk, or a cheap "meh don't need to worry about it" clunk? lmao j/p.
most likely it's your car hitting bump stops.
Something didn't get tightened back up. It wouldn't be the bumpstops unless it only happened when you hit bumps hard enough to compress the springs quite a bit. Put your car on stands, remove the wheels, and wiggle everything.
GTWORX.com
109
Oct 24, 2022 03:42 PM
Kreeker
Oct 27, 2016 07:52 AM
lancer586
Oct 22, 2016 04:34 PM
ProjectGSX
May 27, 2012 07:15 PM
EvoTech
Apr 24, 2007 12:59 PM
