Fog Lights
Fog Lights
Hey guys, does any one have a PDF or download to install the fog light kit. I got a set of rigid industries LED small driving lights that I am planning to retro fit into the fog light inserts, but am looking for a good cable rout or a way to pop those guys out.
Thanks
Thanks
Sure do. OEM install guide attached.
Thanks for the info! I ended up doing my own kit. Got some UTV style lights that are sealed and ready to install with a plug and play kit with all needed fuses and relays. I cut out the inner part of the fog light cover and used some bracketery to hold the lights in place. Ran the wiring up along front of motor and hide all wiring. Ran a wire through the firewall where the main harness goes and up to the dash by the ASC button. Pushed out a blank and still need to cut out a hole to allow the switch to go. Here they are turned on. Gonna test them out tonight! Saved me 200$ Thanks!
Aw man, did you take any pics of the mounts/brackets before you put the bumper back on? I have a set of projector fogs sitting at home waiting for me to find time to fab some brackets.
And mRVR, unfortunately, I cannot edit/modify his attachments as far as I know. He'd have to rotate them, and then edit the post to attach the corrected ones, but thanks for taking care of it!
Glad to help out.
(it was a strain to twist my neck sideways to view those pics any how. )
Seems like we have similar dilemmas...
I finally have the custom hood strut brackets made, but I don't have anyone to help photo/film while I install them, so they're just sitting on my desk.
Same goes for the backup floodlight unit I'd made (based off of your license LED light)
Actually not sure of the wattage. I got them from work as they where old display models and no box or paperwork. I utilized the 3 holes behind the fog blank. Made a U shape bracket that the sandwiches between the light and the pre-tapped holes on the bumper. Ran the wires up along the bumper. Everything is hidden except the relay. The hardest part was going through the fire wall. Had to have the wife help out.
I was going to ask. Where the ASC button is are two extra blanks. Has anyone ever seen one that I can use to switch the lights on/off that would fit in the OEM spot? It need to be a 3 way. If not I'll leave it be. thanks
I did, you will see a giant rubber grommet where the main harness runs through. Poke a hole through there, be careful of the wires behind it. I then ran a wire taped to the harness and fed it down to where the brake/gas pedal is and zip tied everything nice and tight. Start to finish took me about 3hrs from install to putting away tools.
blackoutVIII
Oct 1, 2014 12:10 PM
Titaztik
Jul 14, 2009 07:36 AM
Atssystems
May 4, 2005 01:47 AM
Brandnuevo
Jan 4, 2004 11:24 PM
