2015 HID Xenon headlights
My 2015 ASX has H11 halogen projector. Currently the H11 halogen bulb had been replaced with H11 hid bulbs with 35w hid ballasts/igniters and wiring harness. As soon as I detect any deterioration to the light intensity, I intend to retrofit the headlights with D2S hid projectors, same as the OEM ones. What is the brand, model, and from where can I source these hid projectors?
Did you have any flicker issues when you swapped over to H11 HID? I see those "flicker/warning cancelers" and I'm wondering if I need those.
and you will not have flicker issues so you would not need it since the low beam does not act as the DRL. people only get them if their low beam was also the DR:
i meant there there same as in a direct swap. so if yours came originally with halogens you can get a set of the oem projectors and plug right in. and there are no aftermarket projector options for the OS only oem, so cheapest way to go is find a used set like on ebay or from a wrecked OS, brand new straight from dealer would be way too expensive. or you can send your current ones in to get retrofitted.
Farmerbob
Apr 25, 2010 07:52 PM
carlmalonie
For Sale - Part Outs
12
Feb 18, 2010 10:56 PM
carlmalonie
54
Sep 12, 2008 03:19 PM
