30k service...some questions
I recently had my 30k type C service done along with my low RPM stuttering recall.
Before I got my RVR back I received the dreaded "we have some recommendations for you" call.
Basically I was told that I should get a Brake Fluid flush and Transmission fluid flush as these are getting dirty.
Since I was already doing my type C service ($280.00 CDN) I told them to hold off until next time. If I went ahead with the other 2 options I would have been in excess of $550.00.
I'm just wondering if these type of "flushes" are normal at 30k? Does everyone do these? Are they recommended?
Any past experience would help.
Thanks
Thanks
Thanks
Thanks
Unfortunately Mitsubishi Canada transfers the right to the dealers to set what jobs are need to be done. We have discussed this issue extensively before in another thread.
you should do brake fluid every two years or so - its hygroscopic and absorbs water.
trans fluid seems a little early, but this is my first CVT, so ....
differential fluid and transfer case fluid should also be done at some point, but those are easier than oil changes, so DIY if possible.
I'd say that's way too early for the tranny fluid. I have the manual tranny on my RVR so I don't know much about the Mitsu CVT fluid longevity, but I have a 2003 Nissan Murano as my 2nd car that my wife uses. The Nissan CVT fluid is rated to 150,000kms. A lot of guys were actually having tranny issues after changing the factory fluid on the Murano forum many years ago, so I decided never to change it, 13 years same fluid and my CVT is perfectly smooth and my CVT fluid is still that clearish/green color. I'll honestly never change it on that car.
I did find this pic for reference.
I skipped the 30k, just had it done at 40k instead. With moving and buying a house and such, maintenance was the last on my list surprisingly, lol.
The dealership I took mine to checked the trans fluid, said it was fine. They said they normally don't do a trans flush on the OS's until around 70-80k miles.
30k service
I live in northern virginia which already puts me in the severe use category for vehicle maintenance. Its been a year since i got my 2015 rvr and im already closing in on 25k
i plan on flushing my tranny at 30k (atleast because mines a manual and i want to keep everything up to date with what the user manual says) and i believe im flushing my brake fluid too. id have to double check with the manual.
usually i dont listen to what the dealers say, ill go by my own visual inspection or by exactly what the manual says. Its listed clearly towards the back of the big book
redzfit
Jul 2, 2017 08:32 PM
MitsuJoe
Feb 22, 2006 01:01 PM
