Audio help please
Audio help please
Hi guys I had my OS for about 3 months and the audio sounds terrible. I wanted to replace the system and wanted some advice. What size are the speakers and what size is the main screen? Here is a photo of my unit.
I was thinking about the Kenwood DDX373BT? HERE. What do you guys think? Should I spend more to get something a little better? Basically I want to use my system to mirror my phone while i use google maps or play videos. Also any speakers where i can just drop in without doing custom work to make them fit or are they speakers good enough to keep with a new system? I also have my steering wheel console control. Thanks again for the advice.
The speakers are 6.5. You would need a dash kit for any rsdio you install in there. It still used the factory double din housing. Look up metra. That radio will not mirror your phone. If that's what you're looking for look into the android/Apple car play double din/, those wil mirror your phone. You will also need the harness which metra sells as well. And if you want to keep your factory steering controls you need the metra axxcess Aswc-1
http://www.metraonline.com/vfgapi/vehicle/207245?
No 6.5 speaker will just drop in, crutch field has the necessary brackets and harnesses to fit so you won't have to mess with the factory speaker wires
that unit will only play music from an Android phone, not mirror it.
you want an Android Auto-compatible receiver for mirroring and using navigation.
fujirio (Jul 5, 2016)
you could have just started with the head unit - that is the culprit for most bad factory audio.
you can go crazy with Dynamat, amplifiers, audio processors - its really up to your ears ... and wallet.
The metra axxess steering wheel interface is what you want. You also bought the lax steering wheel interface. They are the same thing. You only need one interface not 2. I would return the pac. Did you also get the radio wiring harness? I see you did not list that
I could not locate that on amazon, do you think best buy would have it since they are going to install it on my car? My appointment is on Friday. Also thanks for pointing out the steering wheel interface, I know nothing about audio so that saves me some cash.
do you know what speakers are currently in the stocked outlander? If they are great i will just send back the speakers I bought.
besy buy will not mostly like have the wiring harness in stock, you have to ask because if you set an appointment and they dont have it theyre going to have to order it and wait for it to come it. the harness you need is 70-7005 it was in the link i gave you "it say mitsubishi harness on it"
the stock speakers are "ok" but aftermarket is good as well. installing the aftermarket headunit will change the sound/quality of the stocks. so just keeo the stocks for now and once you put the radio in and still dont like it then order speakers. oh i see your brought speakers lol missed that. just keep them or install radio first and then go from there
is this true? I can not locate the item any where besides crutchfield.
also the Metra 95-7015CHG would not work with my car so I had to order the Metra 95-7018Chg from crutchfield.
if not, most people just replace the fronts - not much need to replace all - unless you often have audiophiles in the backseat.
nlp187
Jul 8, 2012 10:32 PM
Q8_EVO
37
Mar 1, 2007 03:29 AM
jennz03
21
Mar 14, 2005 10:51 PM
mdacko
Sep 1, 2004 10:11 AM
