More EVO 9 Dyno Results - To Mivec or not to Mivec???
This EVO 9 has a 2.3 Stroker, FMIC, Boost controller, TBE, stock cat and thats it.
The dyno plots show the tune in conservative fashion with 110 octane fuel. Notice the area under the large curve.... Thats with the mivec turned OFF or cams set to 0. Interesting results. Same Boost Pressure, just cam timing is set at 0.
His BOV was leaking pretty good so boost spiked to 26.5 and ended at around 18.
Originally Posted by EVIL_EVO_VIII
Very nice guys!!! Did it have full tbe? Exhaust cam gear?
Can you explain a little more on the curve w/ the MIVEC off? What was the difference?
It held the torque longer thru the range but not in a static manner.
Now we have installed a 9 turbo on a eight this past week with a cam gear on the intake side. We will dyno it this week to show what the difference would be on a stock cammed engine and a static cam gear to show the difference in cylinder pressure. It should be interesting.
Originally Posted by Precision Dyno
The cylinder pressure that the Mivec helped create gave it a chance to increase the ability to develop torque earlier in the band along with maintaining pressure at key points in the band with dynamic changes to the cam profile on the intake side.
Originally Posted by Sharkbite2000
Nice job , i thought i had the fastest Evo IX in the country , we did 400AWHP/512TQ on a stock turbo. we sitting on 540AWHP right now, and by the end of the week we should see 7 and change.
It looks like you have a very nice car. Good luck with all the hard work man. Please keep us posted on your results as well.
Thats on Pruven's Dyno, had to go stand alone to make the real power safe.
