well...the sooner the bettwer for me. I'd like to start data testing my stock fmic vs. the greddy fmic before winter hits us with full force if I could. Did throttle body injection cars have the mat's?
Originally Posted by mrfred
(Post 6339168)
I'm wondering if its worth my time to write a standalone patch because tephra will be including a MAT logging algorithm in his speed density patch.
It would be kinda nice if there was a seperate patch if people didn't want to use the speed density. |
Originally Posted by Jack_of_Trades
(Post 6339926)
Originally Posted by MR Turco
(Post 6340148)
throttle body injection? Is this 1 injector in the TB like a late model carburetor?
gotcha, you trying to see if the Alchy jets are going to screw up your reading (or the sensor)?
Well I got my IAT/CAT/MAT sensor going in next week, so after that I will be experimenting with it.
(Post 6340672)
My sensor is in the UICP about 4" behind my alky nozzles. The original intent was to monitor my intercooling efficiency but I may install it in the IM later on whenever the speed density stuff is all tested and tweaked. |
I had the head off this weekend so tapped that extra bung on the intake manifold for 3/8 NTP while it was out. Let me tell you it was not fun finding the stuff to do it!
I ended up going with a 17/32 drill bit (was looking for 19/32) that was $21 at ACE and got the 3/8 NTP tap at Fleet Farm (they had one at ace, but I had already bought it) for about $7. Then, just a regular 3/8 plug from the plumbing section and I was in good shape! Also, ordered my GM IAT sensor today from BMotorsports.com, $21+ shipping.....they have lots of different plug options too, very informative site! |
Originally Posted by scheides
(Post 6359449)
Got my MAT sensor tapped in today.
Hopefully I will have time for wiring on the weekend. Then I will write the patch into my TephraMod stuff. MrFred - can you disable the fuel temp test with a Periphery bit? Thats my prefered option, disable it then redo the scaling and stuff in my code... |
Originally Posted by tephra
(Post 6362310)
Can't wait to get this working on my car!
MrFred regarding the wiring for the IAT - is it better to wire to signal ground OR engine block.
Obviously this should make *too* much difference - however the ECU wiring guide says to use the "common" sensor ground. Thoughts? |
(Post 6367046)
Wired mine up today and it is working fine!
I will post findings on the BR Race Core very soon.... well... as soon as I get to the dyno. jeje! |
