Cool and I hope you don't mind if I use yours for my Low setting also. When we head to HardTimes that can be the test of settings.
sounds good!
Are you able to set two boosts one for high and one for low?
Also u u know when the lines come out of the solinoid and split into air filter and somewhere else would it be ok if if i still a have that split connected?
anyone?
anyone?
Originally Posted by PVD04
I left the line that goes from the solenoid to the intake pipe connected, but completely removed the line with the T. I also capped off the open side of the solenoid.
woah...so u have thing comming off the stepper motor??? isn't this bad?? |
