Wheatley's 6262 build
#242
I haven't forgotten about this thread Ive just been busy. Tonight I picked up the charge pipes and the parts of the downpipe that still needed to be welded together after we tack them friday. I also bought a bead roller to do the charge pipes I plan on firing the car Friday night after work and changing all the fluids to get it ready to hopefully drive Sunday.
#253
Thank you I really appreciate it.
Thanks, if all goes well with the first drive it will probably be hitting a dyno after the shootout. It was street tuned last year and Id like to hit a dyno before I race it this year.
Thank you, Ive been stressing out about this Shootout deadline. Hopefully nothing major pops up that I can't fix quickly. Right before the first start up I decided I didn't like the way the oil feed was ran and had a banjo break off in the head, luckily it wasn't tight and I was able to remove it and had a spare.
Thank you, will any of the ToxicFab guys be at the Shootout?
Thank you, I think its badass too! Fathouse did an amazing job with this one.
Thanks
I'll have some more pics up once I get it driving and cleaned up, probably around the SO time.
Adam Blevins did the base tune last year to get it running. It was pretty spot on. Fathouse and I do the street tuning when big changes are made. If its just little changes or has anything odd pop up Ill make the changes needed to get it straightened out.
When it goes on the dyno this year Blevins will be at the computer.
Thanks
