Wheatley's 6262 build
#273
43 wasn't really accidental just over my target by a few lbs. For now it will sit around 40 psi unless that's not enough to meet my goals. The aem is pretty easy to setup, I had it about where I wanted it in 5 pulls from wg pressure to the 40 psi range. This time last year would have taken me 20 pulls lol.
The car feels and per afrs is down on power from last year but I figured it would be with the downgrade from the magnus to the stock intake manifold. Hopefully it will help stay in the power band without having to shift at 9200 anymore.
Thank you.
#274
just noticed I apparently can't spell correctly "inspiration" lmao. i'm sure i'll be seeing you at some track days around indy.
also, good to see a cleanly built evo and not some redneck trash or riced out early 2000's inspired honda civic.
#276
Well that makes sense now why your changing oils lol.
I was wondering. Accidental 43psi would have scared the "sh*t" out of me hahaha. The AEM also saved you on fuel man... 5 pulls compared to 20 lol.
Hey man, have you checked the compression? Wondering what your compression is looking like after the rings seat.
#278
hoping to meet a few evo owners when i get out there.
i'll stop the off topic banter and search for the indy threads. sorry OP!
#279
I actually don't own a compression tester. I have a cylinder leakage tester, as long as the percentages are decent Ive never been worried about compression much.
I don't know if you were hanging out with the right crowd. Everyone I know has been doing it at least that long. You probably wont have a lot of luck searching on here for Indy related stuff to be honest.
#282
I heard the news and hated to hear it. Didnt even get to tune on the thing yet to see what it had
But i cant say anything bad about Oliver rods. I've been on them for 20K now on 40psi with 9-9200RPM shifts @ 700+WHP for the last 12-15K id say and the other 5-7K was on 600WHP and haven't had any bad luck yet. Dunno what caused the failure yet but im sure ill find out soon enough.
So are you going to be building another engine or??
#284
Wait until you have to send one back in to have it inspected. Go through 3 months of waiting to get a rod back worse off than it was when it was sent in and causing to you pay for another set of new bearings. On top of that pay for another rod to replace the one they honed crooked and have it sent to you with the bearing locks cut incorrectly having to send it back in again. If that occurs let me know if you have anything bad to say.
Oliver, btw Tim at Oliver said that 9200rpm will be outside the manufacturers limit on the arp 2000 rod bolts for the rotational weight of our engines. Just passing that along, he recommended around 8500 but then again when I asked if I needed to upgrade rod bolts the first time he said no and the second time he said yes after the rods were already done and shipped back out .
The rod that is allowing my crank to see the back side of my turbo was the replacement rod.
#285
Thanks, at this point I doubt I touch it for several months. I've done nothing but wrench on it for months and for it to last just long enough for me to get excited about racing again is a downer. Last year I had nothing but head issues, taking it off and on and sending it back to the shop that did it and now this. With the amount of damage I doubt I have it back together for a few years. At this point I want to get all my debts paid off and start looking into buying another house. I've never been concerned about blowing an engine as long as it didnt window the block or take out my fresh head. I'm pretty sure this did both
