The evolution of my Evo IX RS Wicked White
#214
because you cant modulate all 4 tires at the same time. track surface is not always even and weight transfer not always the same. hard to trail brake without locking up rear inside tires and flat spotting it.
#215
parts for ABS swap
- GSR engine harness
- master cylinder
- ABS pump and ecu
- ABS hard lines
got the old harness out on the engine bay side, will need to remove the dash to get the cabin side of the harness.
- master cylinder
- ABS pump and ecu
- ABS hard lines
#218
Thanks to Agile Automotive Performance for building the motor, and MPG for providing the parts for the build.
2.3L stroker with Manley crank, Manley rods and wiseco HD pistons.
trimming the AMS oil scrapper for the 2.3 stroker. you can see the rod bolts hits the scrapper.
after trimming
this is the only bolt hole on the AMS oil pan that i had to grind down to make clearance for a socket.
I didn't use silicone sealant on the oil return line at first and it leaked. so i used some hondabond sealant and new oem o-ring washers for the oil return and no leaks after that. no other leaks any where else from the AMS oil pan.
after trimming
hokiruu (Nov 26, 2019)
